[ROM] Custom Sunvell T95Z Plus Amlogic S912 With 9377 WIFI Chip
Originally posted by MartBiOs2k View Post
Kernel need to be recompile but i'm not able to do that to add the option in the display setting. I don't have enough skill to play with dev and compile kernel.
BUT, you can try something. you need to create a fine called rgb_mode (a txt file from you pc) and add the number 1 in it.
remove then extension .txt it need to be rgb_mode
copy it into /sys/devices/virtual/amhdmitx/amhdmitx0/
using root explorer then you should be fine. it could be removed or changed after a reboot i didn't try.
For this fix it will probably be included in a future firmware release from Sunvell but for the moment this is not included in my source
I've read that coulb the because you tv is too old and does not accept 1080p source, did you try in 720p ?
Thank you for your Rom, the Wifi is now working! For the RGB fix I did what you recommend but I can't paste the file rgb_mode in /sys/devices/virtual/amhdmitx/amhdmitx0/ . I use Root Explorer and accepted the root access but the paste is impossible. I tried to create it too but no way, no right to write in this folder (or others before). Do I need to do something else to have complete rights?
Originally posted by Stefkus View PostWhat is the RGB issue everyone is talking about? Is this the same as the dark video playback or something else? Maybe this fix can be included in the new release that's coming from MartBiOs2k?
Also currently having an issue with my logitech mouse as it won't go to the right side of the screen, and clicking in the screen is out of alignment, try to click power off when I bring up the menu option on the launcher, it doesn't work, just goes back to the launcher as if I clicked outside of the menu option .... Might be the mouse, might be the box, dunno.
Originally posted by tsubasa42 View Post
RGB issue is with some old Philips and Sony which lead to some green flashes. It is very very annoying. What you are talking about is easy to fix by disabling in Video menu the mediacoder usage.
Thanks.
Guys, Look my 1st post New firmware is here.
the Original T5ZP0032 !!!!
I've test it and it's better then my custom one
Wifi speed it half fixed, upload speed is not bad. download speed and no as good as upload speed and can't stream my MKV in my NAS I,ve try to play with config but did not change.
I've fix keyboard maping, cleanup preinstall thing and add my APPS.
look like it have a special kodi version I didn't try much.
have fun with testing!!
Originally posted by MartBiOs2k View PostGuys, Look my 1st post New firmware is here.
have fun with testing!!Last edited by jseeley; 18 February 2017, 05:02.
There are currently 2039 users online. 0 members and 2039 guests.
