[ROM] Custom Sunvell T95Z Plus Amlogic S912 With 9377 WIFI Chip
MartBiOs2k Can you please update the OP about which apps are included (Kodi version, Netflix, Launcher(s) and what is left out of the original ROM (bloatware)?
If we make request would you consider adding them in next ROM version? I for once would like a power/reboot button or app.
EDIT: and Netflix 4k app ;-)
Sent from my SM-A9000 using Tapatalk
Originally posted by ZeroZorro View PostMartBiOs2k Can you please update the OP about which apps are included (Kodi version, Netflix, Launcher(s) and what is left out of the original ROM (bloatware)?
Here is the list of app included in my latest release
Chrome-56.0.2924.87
CPU-Z-Premium-1.22
kodiapp-armeabi-v7a-0921
Netflix-3.3.2 build1530
QuickSupport-12.0.6197
rootexplore
SimpleReboot-7.0
TeamViewer-Addon-AOSP
TVLauncherv3.0.20
VLC-Android-2.1.0-20170205-0235-ARMv7
WiFi Speed Test Pro v2.5.1
YouTubeTV.xp510
there is a Reboot and Power OFF app included
Originally posted by MartBiOs2k View PostHere is the list of app included in my latest release
Chrome-56.0.2924.87
CPU-Z-Premium-1.22
rootexplore
SimpleReboot-7.0
TVLauncherv3.0.20
YouTubeTV.xp510
Flashed again and let the system alone for 30 minutes...even a restart...nothing. I remember did first time I installed this ROM but I have switched a lot for testing. Any idea how to flash clean-clean??
Back to factory firmware/rom and try again?
Thanks for that list....but....after a ROM flash with USB_BURNING_TOOL those apps don't show up.
Try to download burning too 2.0.7.2 build 2
make sure you have both Erase flash and bootloaded.
You initial boot make sure you don't connect any usb only HDMI and Power.
don't connect to Wifi too,
On you click you should see menu avec 3 min boot, and 2 more to get app installed into app menu
Let me know
Well...i did what you guys told me...
- switched from Burning Tool 2.0.8.0 to 2.0.7.2
- Erase flash (erase all)
- Reset after flash
- No USB/No WiFi/No Ethernet (so only HDMI and Power)
- Changed Temp.Range to 20-60
Only didn't got driver setup, cause i had 2.0.8.0 still installed on my pc
Result....i will report soon! ;-)
EDIT: I see apps are adding....it's working!!! Thanks again guys...few more minutes and i can install Spotify, IMDB, nzb360, MyFritz2, Moonlight (!), MXplayerPro, TeamviewerHost, some Synology apps and do some real testing!
Originally posted by Stefkus View PostThis I received from my supplier (EasyTone) should be the original firmware. But the file is much smaller and has no extension, don't have a clue what to do with it. Anyone?
Link will be active until 27-2-2017
Now I've got a new .img file from supplier. Download button does not work, right-click downloadbutton and save as...
The say it is V10, but don't know how to look into image without flashing it... I think T5ZP0010 is not good for our wifi...
Please let me know which version it really is, if someone is going to test this.
Originally posted by Stefkus View PostI also asked for version T5PZ0031 and T5PZ0032, 31 was on my box originally. I hope they will give me download links for these two as well. If so, I will share them.
I fast the beelink gt1 firmware on my t95z plus and I was able to get 13mbps but the downside was lost of remote and front lcd.
sadly i'm not developper to play with kernel et recompile one, but I can easly customize a source for our needs.
so my goal is finaly found a source that make WIFI work as maximum speed. so hopping that source will come out soon on the internet.
There are currently 2422 users online. 1 members and 2421 guests.
