[ROM] Custom Sunvell T95Z Plus Amlogic S912 With 9377 WIFI Chip
Thanks for this ROM and your efforts @MartBiOs2k !
I hope you will keep working on this and newer firmwares too!
This ROM works great so far (after testing 3 days) but have some questions for now...
Bluetooth keyboard works, Logitech701 works, Moonlight App works (great!), Spotify (Connect) works, VyprVPN works, great!
- Is there a way to go to hamburger menu with the default remote control? I only get there with the mouse...not great although i set it to max speed.
- Also sometimes in some apps it is not possible to get to all the possible (clickable) positions on the screen with the left-righ-up-down buttons. It seems to got stuck in part of the screen and i can't 'tab' to another portion of the screen.
- When trying to open the Status Bar in android it's kind of trial and error, click fast twice or more...i don't know...i also need the mouse for that, i am not getting there with the arrow-keys on the remote.
- I can't get Anymote or Android Remote on my Samsung S4 to find the AndroidTV, Kodi works, but not the main menu. I got it kind of working through my TV and CEC, but not ideal i think.
- If connected to Ethernet AND WiFi it gives an exclamation mark in WiFi (and switches on/off) which disappears when ethernet cable is removed. Is it true that Wifi is faster?? I don't think so but i thought i read something lately about this box.
- I don't understand where the numbers on the remote control are for. I don't see where i would use them, would like to reassign them. Also i can't get to the alphabet when holding the button longer to make words.
Thanks again for your work and for sheding some lights on the questions above maybe!
Originally posted by tsubasa42 View PostMy build is T5ZP0030 and the wifi is currently not working... . I saw 2 customs firmwares but in the description I don't see anything for the rgb fix. Do you think that if I deactive the Deep Color Mode I won't have any green splash screen anymore?
Originally posted by ZeroZorro View PostThanks for this ROM and your efforts @MartBiOs2k !
I'm not sure about all you questions, but first it's an android box connected to your tv. there is no touch capability so you need to do it wil you air mouse like if you drag with your finger you should be able to get all menu and option from app you use.
for the remote, it do basic task, but you should get an air mouse if you want to play with no limitation. the remote can learn you tv remote so that's why # and other key is there to be mapper to you tv remote.
WARNING!!!
A question: I have installed supersu and now wants the Google Playstore root access!?? I've seen there are 2 Google Playstore installed. One with the name "PlayStore" and one with the name "Google PlayStore". The second is the original. The shortcut on the homescreen is the "faked" store... For me this is very suspicious. What's going on there?? Trojans??
I ask for a statement thank you!
Talked about it starting here: http://freaktab.com/forum/tv-player-...=1485976880051
Hello, I have disabled Deep Color but I still have the green flash. Would you be kind enough to tell me how to solve this RGB issue please ? It is very annoying...
BUT, you can try something. you need to create a fine called rgb_mode (a txt file from you pc) and add the number 1 in it.
remove then extension .txt it need to be rgb_mode
copy it into /sys/devices/virtual/amhdmitx/amhdmitx0/
using root explorer then you should be fine. it could be removed or changed after a reboot i didn't try.
For this fix it will probably be included in a future firmware release from Sunvell but for the moment this is not included in my source
I've read that coulb the because you tv is too old and does not accept 1080p source, did you try in 720p ?
Originally posted by Androidum View PostThis Chinese scrap software...Thank you MartBiOs2k for your work!! Without you i would have already returned the box. Chinese shit. Please continue MartBiOs2k!
i'll check if I can modifie the menu to lunch directly the original application
Originally posted by MartBiOs2k View Post
Hello ZeroZorro,
Rikomagic RKM MK705 3 in 1 2.4GHz Portable Wireless Air Mouse QWERTY Keyboard IR Remote
About the Anymote app, do you know which port is being used for the WiFi remote in your ROM MartBiOs2k ? And if i need a username/password to connect to the T95z+.
I ask because the app doesn't find it with the scanning function...
Kernel need to be recompile but i'm not able to do that to add the option in the display setting. I don't have enough skill to play with dev and compile kernel.
Originally posted by ZeroZorro View PostAbout the Anymote app, do you know which port is being used for the WiFi remote in your ROM MartBiOs2k ? And if i need a username/password to connect to the T95z+.
you should see your deveice when scan
There are currently 2369 users online. 0 members and 2369 guests.
