MECOOL M8S Pro + TV Box Amlogic S905X Android 7.1 2/16GB Fast Lan, WiFi 802.11b/g/n
Guest
Okay, it looks like we're going to have to wait until I get my USB Bluetooth dongles before I can get that working. I think we're close, but it will take some iteration with hardware. If you're ordering ones for yourself, I recommend ones marked with CSR 4.0, which are dirt cheap and use the CSR8510 chipset from Qualcomm. That's what I'll be using.
I initially looked at the date I got the M8SPro+ and graphed that data.
Chart 1
So, now I have gone back over my connection speed data and found that the Z28 seems to have caused an issue with my BB supply and a drop in supplied speed.
This is poor but not as bad as the complete destruction of the ADSL service when the M8SPro+ is connected.
When I connect it the server in the supply telephone exchange seems to be affected as it crashes the supply and seems to take about 5 minutes to restore service (if the Mecool is not connected any more).
Before Z28 = 5.0 Mbps
Z28 = 4.3
M8SPro+ = 3.5
Chart 2You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
I don't have ADSL
Have you tested with a good power supply.
Wrapping the 5v lead thru a ferrite core may also help.
You could test with good high powered Battery pack 5volts, bit of a much around
Some (a lot) of these these powers packs can generate JUNK and at a guess only sending it down the line.
or a Bad power Board if plugs packs are plug into a strip..
I'm new to this world of android box's.
I want to have my box on dual boot ( librelec + android tv )
Can you help me to choose the rom for android tv?
For librelec when i put the recovery.img ( download from " Libreelec 7.0 for S905/X " here in the forum) on a sd card and boot the box, it freezes on the Mecool logo....
Can anyone help me?
Can anyone help me?
Originally posted by clarkss12 View PostAsk Wrxtasy on the Kodi forum, he will advise you on how to dual boot into LibreELEC.
Follow LibreELEC install to a SD card - instructions from:
https://forum.libreelec.tv/thread/93...905x/?pageNo=1
After flashing LibreELEC image, copy both dtb.img and remote.conf files to SD card:
Insert SD card, Hold in Reset button as show in this Post while you power up the MECOOL, wait till LibreELEC Logo appears and release button.
http://freaktab.com/forum/tv-player-...688#post660688
In Kodi's power menu select "Reboot from Internal" to reboot to Android.
Originally posted by wrxtasy View Post
Best microSDHC cards for LibreELEC Kodi = Samsung EVO(+), Sandisk or Lexar 300x Class 10 U1
And for the android tv rom?
Im having problems in stock rom, can't play 1080p files on plex app. On kodi, after 10 min of a movie the box freez.
Don't know what to do :/
edit:
LibreElec works great i need now how to install Android TV rom and which rom.
Thanks wrxtasyLast edited by luckyzor; 08-29-2017, 19:32.
edit:
Thanks wrxtasyMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by luckyzor View PostLibreElec works great i need now how to install Android TV rom and which rom.
Thanks wrxtasy
Download OTA UPDATE.zip and save to USB Stick, do not Unzip:
Use Android - Update App, tick "data wipe" checkbox and then do a Local Update using the OTA UPDATE.zip from the USB Stick.
There are currently 1651 users online. 7 members and 1644 guests.
