UPDATED - CX919 - 4.2.2 - Finless ROM 1.6b
Originally posted by Tjee View PostPlease consider making a Donation to freakTab
1.6 ROM pulled! 1.6a uploading
We have solved the issues with some CX-919 sticks not booting or having NAND issues.
Special thanks to Tucker for helping me find the issue!
I am uploading V1.6a with a new recovery.img that solve all issues and will work now on any CX-919 stick.
Stay tuned I will update the first post here with 1.6a and provide a new download link.
Re: NEW - CX919 - 4.2.2 - Finless ROM 1.6
Originally posted by Tjee View PostFor those with touch issues, I'm finding that this kernel: 'Hoabycsr No Overclock (400mhz) 720 frame skip fix' (http://www.freaktab.com/showthread.p...inless-ROM-1-5) (and presumably his alternatives) works perfectly fine with touch options in Tincore Keymapper.
Now all I need is a way to get my X360 wired controller triggers recognized as triggers, and not as a touchpad
Now all I need is a way to get my X360 wired controller triggers recognized as triggers, and not as a touchpadbut I don't use tincore,, I use sixaxis to map touch input iv got the latest sixaxis installed tried sam kernel, stock & hoabcsr & none of them let me use touch input, it lets me create the profile no problem I see the little hands on screen but don't work..
Asphalt 8 works great but I don't have to create a touch profile for thatLast edited by blinkone; 19 October 2013, 11:07.Please consider making a Donation to freakTab
Originally posted by blinkone View PostThis don't work for mebut I don't use tincore,, I use sixaxis to map touch input iv got the latest sixaxis installed tried sam kernel, stock & hoabcsr & none of them let me use touch input, it lets me create the profile no problem I see the little hands on screen but don't work..
I prefer Finless' rom though, but I haven't tested the aforementioned kernel with his rom.
Originally posted by Finless View PostWe have solved the issues with some CX-919 sticks not booting or having NAND issues.
Originally posted by Tjee View PostTry it with this rom. (v. 1.2) That's how I got it to work.
I prefer Finless' rom though, but I haven't tested the aforementioned kernel with his rom.Please consider making a Donation to freakTab
Which 1.4 ROM did touch work on? 4.1.1 or 4.2.2?
Originally posted by Finless View PostWhich 1.4 ROM did touch work on? 4.1.1 or 4.2.2?
Boblol
I cant find a touch.ko module for 3.0.36+ kernels.
I will see if I can get one compiled.
1.6a now available
UPDATE!
New ROM is 1.6a
The only thing changed is a new recovery.img. This will solve the boot problems on some sticks and any NAND formatting issues.
Link has been updated in the first post.
Originally posted by Finless View PostI cant find a touch.ko module for 3.0.36+ kernels.
Bobyou can sort this
Touch Screen support!
OK folks. For those that need touch screen support here is a new boot.img that adds is.
https://docs.google.com/file/d/0B9BF...it?usp=sharing
Download this and unzip it. You will have a file called boot720_touch.img
Put this in my 1.6a FinlessROM folder.
Run the flash tool and change the boot.img line and point to this new boot file.
Uncheck everything else and flash only boot720_touch.img
On reboot touch should now be working.
To confirm you can install Android Terminal Emulator and at the command prompt type
lsmod
It will list all installed KO modules and it should list Virtual Touchscreen as installed.
NOTE: This only works on 720P kernel. It will install on 1080 kernels but the coordinates will be wrong.
Sorry I have not found a touch.ko that supports 1080 kernels.
Enjoy,
There are currently 2044 users online. 1 members and 2043 guests.
