Iv downloaded the boot720_touch, flashed just the new boot720_touch,It flased ok I think, but wont boot up stuck on android open belly with a few options at the top left,,so I decided to erase nand and reflash everything using the (boot720_touch) still the same android open belly
Edit,,just flashed the old boot & im up & running again but with no touch screen support.
I don't no if it makes any difference but I used 1.6 not 1.6A rom
Another thing the boot720_touch you uploaded is not a zip file its a image so I did not need to unzip it
