I dont think you are able to access the 500Gb HDD (powered or unpowered)through any android device. t(hey are mostly limited to 64Gb or 99% of them are 32Gb, maybe I am wrong) unless you have experience otherwise.
Sorry for the late reply coz was sick and in bed for 3 days.
And if you are on the stock PiPo ROM you might face problems of writing to even the sdcard and should quickly upgrade it to the KASTY/RILEY customs ROMs.
The advantages of running customs ROM is that they are "rooted" and for me that is a must coz I always modify the "build.prop" and ,running automaintenace apps on the device like periodic cleaning of cache dan "junk files" will require the roo access by these apps that you can download from app store.
And adding the gps.conf file in the system is a must for a more accurate gps.fix. (I have attached a gps modified files that you need to add to the system folder that a lot of people in other forums have found it to be a cure for the poor PiPo gps. performance. You wouldnt be able to do all of this if you are on stock rom and they all come wit abigger data partition of 4Gb versus 2gb for stock ROM, with 4Gb data partition you do not have to move any apps to sdcard.
GPS HELP Files.zip
