I always get random crashes from every rom including the official minix roms. The only rom that is 100 % stable is the nexus rom for me. Is there a reason for this? I always erase NAND before installing a new rom so that's not the issue. Is minix inconsistent with their hardware?
Minix Neo X7 - Finless 1.7 ROM
Re: NEW - Minix Neo X7 - Finless 1.7 ROM
Originally posted by crowscrow View PostI always get random crashes from every rom including the official minix roms. The only rom that is 100 % stable is the nexus rom for me. Is there a reason for this? I always erase NAND before installing a new rom so that's not the issue. Is minix inconsistent with their hardware?
Big Benster
AW: NEW - Minix Neo X7 - Finless 1.7 ROM
But I think, it makes no sense to turn off essential Android standard features to get a ROM to work.
I'll wait and stay with the Nexus ROM for now.
Gesendet von meinem LG-P710 mit Tapatalk
Originally posted by sebastiaan15 View Posthi finless
init.d does not work
i put in a script that gives always the right permissions to system/app system/framework and init.d
also i put a zipalign script with the right files in system/bin ,does also not work
are you sure you changed also the ramdisk to support the init.d
Sent From My Nexus 5 Powered By Franco Kernel
I have tried all the included kernels and also three different cables... I still have the issue I have been mentioning since the rom release. I have also started clean with nand erase thrice, but it didn't help either.
Every few mins, tv acts like it had lost the connection with minix and reconnected again... This happens repeatedly irrespective of the hdmi mode, kernels or video setting.. Now I'm not sure what to do for fixing this issue but I don't see anyone reporting it here? Really strange that I'm the only one facing this weird problem... Can someone please help me find a fix?
I really like this rom and don't feel like going back to anything else at the moment
Originally posted by Molle View PostI see the same but passthrough still works. Do you have the following entry in the advancedsettings.xml file:
Code:<libMediaPassThroughHack>true</libMediaPassThroughHack> </advancedsettings>
Besides that I don't have anything out of the ordinary in my settings. Audio output in XBMC settings is set to HDMI/5.1 and the Android sound setting option is at "RK29_RT5616_PASSTHROUGH".
Make me wonder how you got an option that is unkown on my device. Is this related to libmedia.so?
Originally posted by krispuniq View PostI have tried all the included kernels and also three different cables... I still have the issue I have been mentioning since the rom release. I have also started clean with nand erase thrice, but it didn't help either.
I only wonder what is causing the hdmi to reconnect on 60, any devs knows the influence of this?
Originally posted by Heire View PostI have checked and I do have this setting listed however what I find strange is that you have an android sound setting that is not visible for me namely the PASSTHROUGH option. I only have the SPDIF option with passthrough and a RK29_RT5616_5.1Multichannel which I have no idea what that could be.
I can't yet say about XBMC as I have to copy a patched libmedia.so file but stock rom is not rooted. So, I am trying to get there.
Bob, Could you look into this please. I think DD/DTS passthrough in HDMI is important to a lot of people who use DD/DTS receivers. Thanks in advance.
Originally posted by Vishwa Somayaji View PostI have been struggling with the same issue. I spent hours and have some ideas what is happening. This is my theory. Molle is using the stock firmware or the rooted stock firmware where you see the RK29_RT5616 Passthrough option as the last option. If you load any of Finless 1.7 roms, that option is gone and instead, as you wrote, the RK29_RT5616_5point1Multichannel appears as the last option. Logically, that should be the same(a little more descriptive) but doesn't work as intended. I tried many times. Even the stock video players(there are three of them) don't work in pass through mode. It seems to be decoding internally and sending LPCM as my onkyo shows pcm. Then I reflashed with stock 007 rom and DD/DTS works fine with stock player.
Originally posted by Heire View PostI thought he was using the finless rom, so he should be more or less similar as what I have yet there is a difference.
Originally posted by Heire View PostHave you tried settings the hdmi settings to 1080p30 instead of 1080p60, this solved my issue.
There are currently 1805 users online. 0 members and 1805 guests.
