Ugoos UT1 - wasser firmware - JB Android 4.2.2
    Originally posted by obutron View Post
    Thank you very much SLHQC. It worked.
    You're welcome. Glad to help!
      Finally some feedback from me wasser. You gave me the advice to buy a new power adapter because of the instabilty. You were so right. Your latest ROM runs smoothly like no one before, great work!
      Danke für die Hilfe und die ROMs
        Help Needed
        Hi Guys, I'm new to the world of these awesome players but I'm stuck and I don't know what I am doing wrong, so any help would be greatly appreciated.
        I've gone to flash my ut1 and it keeps saying that "KernelFile is not Existed". I have already "EraseIDB", so I'm worried about disconnecting. I have checked and the files are in the sub folders and I have re extracted them from the original download.
        I have no idea if I am missing something really obvious.
        Thanks in advance.
          Ignore previous post
          Ended up that my download had been corrupted.
            Thanks in advance.
            If you get stuck then follow Pablo's guide.Everything is explained clearly.
              Seems like the UT1 is not popular anymore
              Sent from my HTC_0P6B using Tapatalk
                Yes it is maybe you can add some new features wasser
                  i don't think so because i'm still working on kikat firmware for UT1. I hope get it done this weekend.
                  highlight of my coming kikat release is perfect fullhd video streaming.
                  wasser
                    Ut2 you mean? I cant wat to test it
                      I am very happy to hear this wasser You do mean UT1 don't you? You're talking about your previous kitkat rom for UT1?
                        wasser
                        good to hear. UT1 is very much in use here
                          wasser
                          Good to hear
                            Yes, it's much better than UT2. For example:
                            UT2-WLAN (acc. to photos on product page) has only 65MBit/s (20MHz bandwith)
                            UT1-WLAN has 150MBit/s (40MHz bandwith, self tested)
                            UT2 WLAN has only one antenna (no antenna diversity)
                            UT1 WLAN has only two antennas (antenna diversity for best quality)
                            Small problem with wasser firmware: wetter.com-app is not compatible.
                            @wasser: thank you for this great firmware. It's much better than stock firmware!
                            Best regards
                            akapuma
                              Ut2 does 480mbit on wlan, self tested. Even though 65mbit is sufficient for streaming the most heavy files.
                              Bad example of it being 'much better'
                                UT2 has only one antenna. For a nominal data rate of 480MBit/s, 3 antennas are needed (802.11n-standard).
                                Is the UT2 using the 802.11ac-standard? Can you post a screen shot, please? All screen shots in the internet shows only 65MBit/s, like here.
                                Best regards
                                akapuma
