Ugoos UT1 - wasser firmware - JB Android 4.2.2
    Originally posted by Paul Taraneh View Post
    Wasser, new to flashing gonna try version 092 above am i correct in Reading that i won't have to flash a kernel separately?
    If i do, then which one?
    Please advise....
    you have the flash kernel from 0.92 because the kernel from 1.2.4 doesn't work correct in kilat!
      I'm getting confused with all the different kernels around, can you please direct me towards the one you're speaking of? Much appreciation in advance.
      So flak the rom, flash the kernal, reboot, and that's all?
        Which kernel do i use with 1/.2.4 zip? So many on here in confused just got my box want the correct firmware please advise.
          for 1080p resolution: use boot-1080p.img and kernel-1080p-ut1.img
          for 720p resolution: use boot-720p.img and kernel-720p-ut1.img
            version 1.2.4
            - kikat laucher
            - wifi support
            - ethernet support
            - init.d support
            - 1080p24hz, 1080p30hz, 1366x768p60hz support
            - frame skipping fix for video play
            - rooted
            - ntfs, nfs, iso, cifs filesystem support
            - 40% like performance boost
            - preinstall es file manager, reboot
            - new kernel, improve sleep/suspend, stability
            - cwm recovery
            - support static ethernet mac adress
            - fixed lan rx network traffic
            - fixed tv-out bug
            Link download:
            1.2.4 firmware for UT1
            RKBatchTool.zip
            Be aware: it is your own risk!
            Installation info:
            1. run RKBatchTool--1.7.exe tool which is included in the zip file to flash the firmware
            2. select the firmware image then click restore button to
            flash the firmware
            please post your feedbacks, it's very important
            Omg, how did you get everything to run smooth? I finally installed this and sound is superb, Web responsive very much i am using Ethernet though. Clear images, great idea to take all the bloat out of the system rom, great great man i must ask?
            Can i use gravity box with this and if so is it a jelly bean rom with 4.4.4.2 settings or actual kit kat?
            *I have used rom tool box to change boot images and find, no problem ..
            Would you be interested in knowing my tweaks to your room? A wasser remixed lol)
              Ethernet not working
              Just flashed the following:
              UT1-Wasser-1.2.4 firmware with
              boot-1080p.img
              to my Ugoos UT1
              Wifi works but ethernet does not, what did I do wrong? I read thru the threads in this posting and didn't hear any one else with ethernet issues, but ethernet is supported but not functional.
              On stock firmware firmware ethernet works perfectly fine.
              Let me know if you I can provide further information. Thanks!
                Ugoos UT1 - wasser firmware 1.2.5 release
                Hi all,
                i even uploaded 1.2.5 firmware. For more infos, please take a look at my first post!
                Enjoy the 1.2.5 firmware!
                Wasser
                  Hi all,
                  Wasser
                  Thank you for putting in the time to do this. I'll give it a try tonight!
                    Thanks mate.
                      How to install this software
                      Many thanks Wasser for your good work!
                      I would like to install the software, but as I'm a total newbee I was searching for instructions how to do it. I found this blog: http://blog.arinium.fi/2014/01/howto...-on-ugoos-ut1/ where is told that I should use the RKAndroidTool if the software is containing several img files. This tool is also included in the file from Wasser.
                      I downloaded the Wasser software, containing 2 kernel files, of which I would use the 1080p version, and the \rockdev\... files which contain 5 img files. Should in my case only installed the boot-1080p.img file or also the misc.img, the recovery.img and/or the system.img file?
                      Many thanks for your answers.
                      Hans
                        Hans
                        you need:
                        boot-1080p.img
                        misc.img
                        recovery.img
                        system.img
                        parameter
                        RK3188Loader(L)_V1.24.bin
                        there's a readme in the zip file. Please read it!
                        wasser
                          boot-1080p.img
                          to my Ugoos UT1
                          After WASSER updated the version to 1.2.5
                          Flashed it to my Ugoos UT1 using the 1080p boot.img and kernel.img everything seems to work great.
                          - Wifi works
                          - Ethernet works (didn't on 1.2.4)
                          - Include remote works great!
                          Thanks for the hard work Wasser!
                            Wasser 1.25
                            Gonna load up 1.25 tonight and see how it goes. Been waiting to flash again till it came out. Hopefully this fixes the (infrequent) lockups I've been having.
                            If you are looking for 1.25 check the OP!
                              Thanks for the firmware wasser.
                              I have been using it (1.2.5, 1080p kernel) on my UT1 for an hour now, internet connection on ethernet and WiFi is good, had no issues streaming HD content. It is relatively stable, no crashes.
                              Got a score of 16030 on AnTuTu.
                              @wasser, would you be able to make an overclocked kernel for the UT1?, maybe a slight overclock on the CPU from 1.4Ghz to 1.6GHz.
                                Hi there,
                                Can anybody give me some advice here ?.I'm going to try Wasser's rom but the batch tool is not recognizing the UT1.I already rooted the device a few weeks ago,so the drivers were good.It shows up in the device manager (windows 7) and I can transfer files using Moborobo but can't get anything to work with the batch tool.I've tried re-installing the drivers,different cables,rebooting everything,recovery mode,normal mode......the list goes on.Any ideas ?
                                Cheers Vinny
