Ugoos UT1 - wasser firmware - JB Android 4.2.2
Hi Wasser, great work.
just some feedback on the firmware.
When shutting down, the blue led does not go down unless I use the remote shutdown button.
The original remote works fine except the mouse mode that does not work.
I'm using the 720rom beacuse the 1080p didn't boot (I tried several times to boot but the image never appeared on the screen).
Question: is there a way to control the UT1 with a mobile phone and a remote app (just like the one that came with the original firmware)
Originally posted by stefjnl View PostFYI the remote issue for me is with the remote control android app that you could download via the stock firmware, not with the white remote control that came with the device. any updates on the 1.2.5 firmware wasser?
thnx!
Originally posted by enochho View PostWasser,
i just update your latest kernel for my UT1 which is running your 1.2.4 rom. But it still freezes when playing high quality 720p video. I think it has problem when playing high bitrates video. When I play a iptv app which get normal hd quality video it doesn't freeze at all.
It works for me without any problem!
Originally posted by zeekapitein View Postdo you have some updates wasser?
thnx!
Originally posted by wasser View PostAre you playing your videos ober lan/wifi? It could be problem on your lan/wifi route.
I was using wifi. But I'm sure it's the video playing error. Because the screen freezes with a lot random red lines on the screen (similar to a graphic card error for a pc) with loud humming noise. Then my UT1 will restart itself.
Since I tried this kernal http://www.freaktab.com/showthread.php?10581-UT1-Kernel yesterday, I haven't seen the freezes/graphic card error again.
fcked my USB port
Wasser, I need some help...
When flashing your image my Laptop apparently went to sleep and now my UT1 does not get recogised my the Laptop anymore. I get a device descriptor request failed message and a 43 error code in device manager. Uninstalling and reinstalling the drivers does not work.
Any clue what could have happened and any idea how I could solve that issue?
Anyway, the box still boots and the installed ROM appears to work normally. Also CWR works, though I am not sure how I should navigate there as there are no vol buttons (?), so is it possible that you can provide us with a CWR flashable zip once you realease 1.2.5 and thus letting me update without a laptop?
Anyway, thanks for your help!
Originally posted by wasser View Postversion 1.2.4
- kikat laucher
- wifi support
- ethernet support
- init.d support
- 1080p24hz, 1080p30hz, 1366x768p60hz support
- frame skipping fix for video play
- rooted
- ntfs, nfs, iso, cifs filesystem support
- 40% like performance boost
- preinstall es file manager, reboot
- new kernel, improve sleep/suspend, stability
- cwm recovery
- support static ethernet mac adress
- fixed lan rx network traffic
- fixed tv-out bug
Link download:
1.2.4 firmware for UT1
RKBatchTool.zip
Be aware: it is your own risk!
Installation info:
1. run RKBatchTool--1.7.exe tool which is included in the zip file to flash the firmware
2. select the firmware image then click restore button to flash the firmware
please post your feedbacks, it's very important
Wasser, new to flashing gonna try version 092 above am i correct in Reading that i won't have to flash a kernel separately?
If i do, then which one?
Please advise....
There are currently 1663 users online. 1 members and 1662 guests.
