Ugoos UT1 - wasser firmware - JB Android 4.2.2
    Flash firmware and kernel and boot image at the same time using the correct flash tool.
    Sent from my HTC_PN071 using Tapatalk
      Originally posted by wasser View Post
      very strange, the stock ir-remote works fine for me. can anyone reproduce this problem?
      wasser
      My remote controller may be special, it came with the Chinese version box what the name is "kaiboer F4". And I saw some same issues at Chinese forum.
        So is mine and I have no issues. UT1 is Kaiboer F4 hardware with Ugoos brand name on it. Exactly the same.
          [QUOTE=akapuma;125727]Which tool is needed to flash this img-file?
          Can somebody give me a short description, please?
          Wanted to give you a professional review butg...on on my rom cut down after two weeks continuous reboot not sure why but im in process of flashing 1.2 .5 if you're interested in specific details of those two weeks running 1.2 .4 let me know
            The flash tool is in the zip from the OP. I wrote a quick guide several posts back in this thread
              Wassa has this now. Can't keep sharing - sorry
                Originally posted by pablo11 View Post
                This is for wassa only really. Latest stock Kaiboer F4 (UT1) software with 1080p kernel from the factory. They gave me permission to share - but I will only leave this up for a short time. Dated this month. https://dl.dropboxusercontent.com/u/...-2.0.8_V02.zip
                Wow Thanks...
                Is there a Changelog from Kaiboer???
                Svemo
                  No, except that the last couple they sent me have the new launcher.
                    Contains a lot of bloat as usual
                      Thanks..
                      mhh i wait for Andriod 4.4 for Kaiboer F4 (UT1)
                      Svemo
                        version 1.2.5
                        - preinstall es filemanager, reboot, hwkeyboardhelperdemo
                        - tvout fix
                        - 1080p/720p boot and kernel images
                        - cwm-recovery
                        - rooted
                        - init.d support
                        - 1080p-24hz, 1080p-30hz, 1366x768p60hz support
                        - nfs, cifs, ntfs, cdrom filesystem support
                        - add launcher switcher
                        - add auto hide systemui
                        - add eth notification title
                        - add screenshot
                        - remove google searchbar
                        - remove cpu/ddr lock on rk3188t
                        - stock ir remote fix
                        Link download:
                        firmware without kernel:
                        http://www.freak-tab.de/wasser/firmw...sser-1.2.5.zip
                        1080p/720p kernels:
                        version 1.2.4
                        - kikat laucher
                        - wifi support
                        - ethernet support
                        - init.d support
                        - 1080p24hz, 1080p30hz, 1366x768p60hz support
                        - frame skipping fix for video play
                        - rooted
                        - ntfs, nfs, iso, cifs filesystem support
                        - 40% like performance boost
                        - preinstall es file manager, reboot
                        - new kernel, improve sleep/suspend, stability
                        - cwm recovery
                        - support static ethernet mac adress
                        - fixed lan rx network traffic
                        - fixed tv-out bug
                        Link download:
                        1.2.4 firmware for UT1
                        RKBatchTool.zip
                        Be aware: it is your own risk!
                        please post your feedbacks, it's very important!
                        This is frustrating, so this update can't be flashed with batch tool? The formate contains no images anyway. I tried to install Dev tool and won't recognise my device yet moroboro does. Where are the image files for entry dev tool? All i know is on 1.2.4 my device reboots especially when using Internet radio. I want to fix that issue. Please advise, guess I'm still a newbie.
                          What kind of launcher is it? The original launcher was terrible. Is this launcher more like stock android?
                            3d launcher. Much faster but in my opinion still not finished. I would wait for wassa to see what can be done with it.
                              Hi Pablo,
                              Thanks for the infos, i will take a look at this today!
                              wasser
                                Waooo, 1080p from the factory? Most Chinese users are using 2.1.6(or less) rom with 720p kernel! Kaiboer didn't released any rom with 1080p kernel. They call the 3d launcher "KIUI", the newset is KIUI 7.0
