Ugoos UT1 - wasser firmware - JB Android 4.2.2
    Well they told me it was 1080p. I haven't benchmarked the rom. It does have the 3d launcher as I said. Don't know what anyone else in China is using but I only got this just over week ago. 206 version was back in January. This must be fairly recent.
    Sent from my HTC_PN071 using Tapatalk
      Originally posted by pablo11 View Post
      So is mine and I have no issues. UT1 is Kaiboer F4 hardware with Ugoos brand name on it. Exactly the same.
      I flashed the box again, nothing was changed. The play/pause key is very important to any player software, but it doesn't worked. It made me very depressed.
        I seem to be having the same issue now.....
          Strange, I will try the stock video player
            I've tested mxplayer and xbmc, play/pause key do not work, the issue is there obviously...
              i will check. Does the play/pause key work in stock firmware?
              wasser
                Yep
                  sorry, what is stock player? what is stock firmware?
                    Stock player is the built in rock chip video player.
                    Stock firmware is any firmware provided by the manufacturer and has not been modified.
                      Pause/play button works with stock rock video player in wassa's rom but not mx or BS player.
                        1. Originally posted by pablo11 View Post
                        That's right. And it's ok in stock firmware. I used stock firmware several months.
                          I'm not sure if this is rom related or its a problem with the box, but every time I boot up the date and time have changed. Today it went back to 1/01/1970. As you know that when date and time are wrong in Android, almost nothing works right. I don't mind having to reset now and then but it's a bit annoying having to do it every day. Anyone else had this problem?
                          Vinny
                            Re flash it again
                              Sometimes the time problem is caused by lack of network on boot - depending on your settings.....
                                I was thinking it might be something like that.My UT1 is connected to my router via the ethernet.Yesterday the ethernet symbol in the status bar was white instead of blue.I could still surf the web and use apps.Later it changed back to blue and all was fine.Left it on overnight and this morning the time and date had changed again,so it's either my router or some app is causing it.
