Ugoos UT1 - wasser firmware - JB Android 4.2.2
    Originally posted by akapuma View Post
    UT2 has only one antenna. For a nominal data rate of 480MBit/s, 3 antennas are needed (802.11n-standard).
    Is the UT2 using the 802.11ac-standard? Can you post a screen shot, please? All screen shots in the internet shows only 65MBit/s, like here.
    Best regards
    akapuma
    1 antenna will do for the b/g/n standard. Even the most cheapass usb thing i got does 300 mbit on my 4 year old not zo cheapass Asus router. I will make a shot any time soon
      Hello wasser,
      with your great firmware, the ugoos UT1 identifies as Samsung GT-I9300. As I wrote already, the GT-I9300 is not compatible with the app from wetter.com.
      Regarding the wifi discussion before, I want to identify the wifi chipset with the app Spec Device. But this app is not compatible to the GT-I9300, too.
      Is it possible to use a more compatible identifier to your new planned KitKat firmware? For example, a Samsung GT-N5100 seems to be much more compatible (both named apps above will work).
      Thank you in advance.
      Best regards
      akapuma
        Hello wasser,
        Is it possible to use a more compatible identifier to your new planned KitKat firmware? For example, a Samsung GT-N5100 seems to be much more compatible (both named apps abowe will work).
        Best regards
        akapuma
        I think UT1 wifi chipset is same as for my CX921 cause UT1 kernel works perfect on my box. CX921 has RTL8188EU wifi chipset, should be the same for UT1.
        Donations are welcome and will be shared with other devs:
        DONATIONS
        CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
          Originally posted by wasser View Post
          i don't think so because i'm still working on kikat firmware for UT1. I hope get it done this weekend.
          highlight of my coming kikat release is perfect fullhd video streaming.
          wasser
          Excited for the release
            You dont need an untrusty app to prove we are wrong or right. Just find the link states and speeds from out your wifi router
            Another tip, while you're at it: set to wifi n only for even more speed at 2.4ghz. Mixed mode is max 150mbit
              I opened my UT 1. The used WIFI chip is Realtek RTL8188ETV. The maximum supported WIFI speed is 150MBit/s, see datasheet. The UT1 supports "antenna diversity", see datasheet, clause 3.2. "Antenna diversity" tests both antennas, and uses the better one. This method is to avoid "standing waves". This is a big problem for WIFI, because the waves are reflected on walls etc.. Therefore, boxes with 2 antennas are much better than boxes with one antenna, like UT2.
              Regarding the "not compatible" problem with some apps and the wasser firmware, I found a solution:
              - Install the app on a compatible device, like your smartphone
              - Save app with appsaver
              - Install apk on ugoos u1
              Best regards
              akapuma
                How's that new kitkat firmware coming along wasser?
                Can't wait to try it. I tried the other one from AllMiniPc but Ethernet loses it's MAC address.
                Thanks in advance
                  wasser
                  any update on the new fw for ut1?
                  thanks
                  holli
                    KitKat 4.4 we want it we love it
                    The firmware for the ut2 is out, when is it our turn ? Of Course you are busy wasser but all of us are waiting.
                    Sorry my bad. The firmware can be downloaded.
                      i even released it for UT1 too,
                      Enjoy,
                      wasser
                        Thank you
                        Thank you very much. I am going to try it at once.
                          correct firmware for UT1 is uploaded. You can download it from the link in the first post
                            Thank you very much will try it out now.
                              Link first post
                              But is this the firmware 4.4 in the first post. I do not understand. What will i be downloading when i download from first post.
                              Regards,
                                [QUOTE=Transcend;179525]But is this the firmware 4.4 in the first post. I do not understand. What will i be downloading when i download from first post.
                                Regards,[/QUOT
                                you have to download it from here
