Pipo M6 Pro RileyROM 1.6 [Last Stable Jellybean]
Originally posted by min0taur View PostI tried to flash this rom from 1.8 kitkat
1. Erase iDb using tool from kitkat then close after done.
2. Flash using tool from this rom
* in status window it resets the tablet but sadly the tab wont detect by the PC again
I tried to press the reset button, and other combinations with no luck
I had to reflash 1.8 kitkat.
Finally I managed to flash another Jelly Bean Rom with Rockchip Batch Tool. Even with that was some hassle with two trials to flash.
After that I was able to flash also Riley 1.6 with its flashing tools.
Originally posted by hikka View PostI had also difficulties to go back to Riley 1.6 after 1.8 Kitkat.
Originally posted by min0taur View PostIts ok now running 1.8 RileyRom KitKat again.
If you mean before it doesn't power on nor charge (Because the problem occurs after I erase Nand)
What i did:
1. Pluged in wall charger
2. Leave it connected to the PC
3. After a few minutes it gets detected I erase Nand again and reflash kitkat
tab is very slow and laggy
Hi all
I am using thi fw from 4 5 months it is working like charm..
But now i am facing problem that my tab goes very laggy and slow. I have flashed the fw again but the tesults ate same. Please someone tell me what happened with my device.
And sorry for my bad english
Hi kaleem, I have noticed this very same issue. Cleaning up caches seems to help, but I think other only way to sort it is to reflash but making sure you fully wipe the machines nand when you flash. Make sure you have no bug apps multi tasking and you should also find about 5 mins in the tablet goes back to normal
I did try KK but I had some big stability issues while on KK and a super sensitive screen. kk though did have much better memory magement even though my physical ram was less when flashed by over 200mb. I am debating KK again for a bit to see how the newer version is, I used the original "stable" March version.
Sorry but I think that is the price of us getting a high spec but ultimately crazy cheap tablet
Originally posted by dibnah View PostHi kaleem, I have noticed this very same issue. Cleaning up caches seems to help, but I think other only way to sort it is to reflash but making sure you fully wipe the machines nand when you flash. Make sure you have no bug apps multi tasking and you should also find about 5 mins in the tablet goes back to normal
You are absolutely right bro i also try kk but the same stability issues with my device.
Cheap things always sucks.
But what we could do now
To make it useable.
for now all you can do is keep an eye on app threads that run in the back ground and kill them, advanced task manager will help identify rogue tasks. You can then issue a stop running within the system settings app which comes with the tablet. Also you need to clean your caches every few weeks, I use Ram Manager pro for this or Clean Master.
All the above are on the market. On the KK front I dont think personally the M6 will get any more updates from Pipo whether JB or KK now the P1 has come to market. I think this is why KK was only ever an unofficial release via their facebook page as the bugs werent fully ironed out.
To be fair to Pipo though, their firmware is no worse than many others and I have had similar issues on Samsungs and other highend devices running android, and its a whole bunch better than Ios (my work has forced IOS upon me for the last 4 months and its hideously buggy). Many of the KK issues can be seen on other devices running KK, so time to sit it out a bit while Google release the next food version of Android
Originally posted by dibnah View Postfor now all you can do is keep an eye on app threads that run in the back ground and kill them, advanced task manager will help identify rogue tasks. You can then issue a stop running within the system settings app which comes with the tablet. Also you need to clean your caches every few weeks, I use Ram Manager pro for this or Clean Master.
I am also using clean master to reduce load on ram
Yes i also thinks that no update will come from pipo because many new models have been in market now
Well the only thing we can do is to wait for new firmwares.
I haven't seen an update for the M6 Pro since February...all of these versions have been based on that last firmware. I've asked Anna Ye at Pipo if there were any updates....she says no. But I'll keep looking.Randy
But now i am facing problem that my tab goes very laggy and slow. I have flashed the fw again but the tesults ate same....Last edited by porthos; 14 July 2014, 17:26.
There are currently 1390 users online. 1 members and 1389 guests.
