MK809III AP6210 NEOTV CROM Version 2.0 1080p
    Hello Folks,
    Now it is here, my new Rom for the MK809III.
    This Rom is not based on a Rom, this Rom is built from the Minix SDK Sources.
    With this we have a Lot of new options in this Rom.
    What Works?
    Everything except Bluetooth.
    I am working to fix this, but think the most People don´t use Bluetooth.
    Also, my Time is rare at the Moment and I don't want to wait a Week longer
    to release this Rom.
    What´s New?
    - New Power Off Menu with Standby and Sleep
    - New Output Options under HDMI Settings
    - HDMI Passthrough
    - Change of the Default Launcher from Settings
    Included Software:
    This Rom comes naked, only SuperUser and FlashIt! Installed.
    What is Flash It! ?
    This is a Software make by me. With this Software you can do the following:
    - Install my Extra Software Package
    (File Manager, Reboot App,Black Screen,FreakBrowser,No Frills CPU Control,Terminal Emulator)
    - Change the Screen Density
    - Spoof the Device as Nexus 7
    - Download and install SPMC or Beyond XBMC
    - Flash Overclock Kernel without PC!
    The Rom has also init.d Support and come with some Pre Installed Modules for:
    -NTFS Support
    -CIF Support
    -XPAD Support
    -Some USB Network Adapter
    -Some USB Sound Cards
    If have Tested the Video Streaming with Plex Media Server and it Works perfect.
    Download:
    *Uploading right now needs 40 min to finished 20140113 00:43 CET*
    Have Fun !
    Neomode
    Thanks for yet another ROM, much appreciated. I do have a question though, you have enabled 720p, 1080p and more HDMI output resolutions, thank you. However, can you change the internal resolution to something more usable? Maybe even offer a couple of different kernels for different internal resolutions. It is great to have HDMI output at 1080p but a bit of a nuisance to have a tiny display resolution internally and so little usable screen estate, adding most widgets is almost impossible as they take up an entire screen. Also a fair bit of content is missing from the playstore due to the internal resolution being detected as a small phone.
    Thanks for your time and patience.
    WFB
      Installs fine on the MK802IV but plex doesn't work so back to 1.9a.
      Ahh well worth trying and great effort
      Mk802IV Neomode 1.9a original rom 720p
        also sorry netflix is still really bad.. experiencing stuttering issue as well. picture shakes when fast movements in the movie. - MK809IV
        launcher still not fixed. it's not sized properly.. it's displaying not at full screen. using NOVA launcher.
        also if you could fix bluetooth it would be great. it's good for bluetooth headphones. Thank you, Neo!!!
          old wifi?
          It works for Old Wifi?
            Originally posted by neomode View Post
            Hello Folks,
            Neomode
            I use Bluetooth keyboard and mouse...lol
            Keep posted on progress of Bluetooth fix so I can test your latest creation.
            Thanks Neomode
            HK1 Pro Plus
            FlowFon F1
            H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
            MXQ Pro+
            R-TVBOX Mini+
            MK809III
              Hi Neomode
              Yes please work on bluetooth I cant use version 2.0 on my Pioneer Appradio
              Sendt fra min GT-I9505 med Tapatalk
                AW: MK809III AP6210 NEOTV CROM Version 2.0 1080p
                For all please take a look in Flash It!
                There you can Set different things like Screen Density, Device Spoofing and Flash OC Kernels.
                Neomode
                  Wifidiplay?
                  Are there wifidiplay and rkgmecontrolsetting apps?
                  Tahnks
                    Bonjour,
                    Les applications souhaitées sont inclus.
                    Avoir test amusant.
                    Cordialement
                    NeoMode
                      Hi Neomode
                      First, thanks for this update. I will try it on my MK802IV as soon as possible.
                      How is the 1080p video playback with XBMC or Beyond XBMC ? Is it smooth, or must I have to install an overclocked kernel ?
                        Should be fine with Standart Kernel.
                        For OC Kernel you need Extra Cooling.
                        Neomode
                          Even with 1080p movies and HD sound ?
                            Neomode, thank you very much for your work.
                            Can I use this ROM for old wi-fi, if I use an external wi-fi (RTL8192cu chip)? In the ROM for old wi-fi, I just rename the modules in system/lib/modules/rtl8192cu.ko in system/lib/modules/rtl8188еu.ко. and it worked for me. This ROM which module is used for WiFi ap6210? And one more question. Neomode, perhaps you have NFS modules for kernel 3.0.36?
                            Thanks again for your work.
                              Thanks Dude !!!
                              I got 1080p on my CozySwan S400
                              ... TVDroid
                              > > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
