MK809III AP6210 NEOTV CROM Version 2.0 1080p
Originally posted by locolars View PostHK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by neomode View Post@magnuss33
Please share with me your Kernel you using. Because that Kernel I have only going from 1200 to 1400.
Neomode
Also, running kernel3 in 1080p mode gives me lots of green pixels running through the picture. They go away when set mode to 720p.Last edited by imaddiced2u; 19 January 2014, 16:53.HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by potard View PostHere is the stock rom for my mk 809 III R-Box. It allows cpu to run from 300MHz (or maybe 400?) to 1,4GHz. Link: https://mega.co.nz/#!PFtlCCYa!Fkwhvj...d7fsDEhnEy-jqQ
Hope it will be usefull for Neomode.
With RKbatchtool here: http://blog.geekbuying.com/index.php/firmware-download/
First linkMK809 III - Geekbuying december 2013
what is the best version of xbmc to use with mx player for 1080p videos?
Yesterday i try a little this rom and work very well (i bought a usb-->lan adapt a so i can see videos from nas), but 1080p look like always in buffer (about 15 sec of video than stop than other 15 sec).
Other question: is possibble to reset at initial state after flash without flashing again?
Thank you
My stick (MK908 III) has:
Model number: rk31sdk
Vendor oftware Version: RK3188_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130514
Wifi chip: AP610 CODA062 1344
Motherboard: 2013-06-17 CYXTECH_RK3188_909 V1_1
On splash screen my say "smarttv" and then "googletv".
It is equal to yours?
Re: MK809III AP6210 NEOTV CROM Version 2.0 1080p
I finaly was able to get decent video playback quality in Netflix and other apps by playing with density settings and CPU speed. I used Neomode's tool. now WIFI is driving me crazy. it depends on how the wind blows… very unstable. I'm looking for USB WIFI dongle.
Neomode do you think you could make this to work with the rom or it should be plug and play? Thank you.
http://www.****.com/itm/802-11n-g-b-...item2ebdf79c18Last edited by mymkv; 21 January 2014, 20:21.
Better Price for that - http://www.****.de/itm/Mini-USB-WiFi...item258315d95d
But i think this cant work with a Android Stick.... TVDroid
> > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
There are currently 2345 users online. 2 members and 2343 guests.
