MK809III AP6210 NEOTV CROM Version 2.0 1080p
Originally posted by Jaman42 View PostHi guys,
I posted in the UG007 thread but was adviced to post here aswell. I recently bought a UG007B, I can't get wifi working with any of the custom roms I have tried so far, any advice on which one I should install?
I read that someone had the neomode 1.9a working so I tried that, works fine but no wi-fi, I liked the interface of 2.0 but no wi-fi. I confirmed the wi-fi working with the original rom before i flashed it.
I just checked and the wifi it is called AP6210, if I haven't misread anything that should be the new version right? That's strange, anyone have any ideas why it doesn't work? I hit enable wi-fi and it says enabling wi-fi or something like that but it never goes online so it never displays the available networks.
I understand that there are others having the same problems.
Any helping advice for this poor android tv stick noob?
*edit: I read the post in the 1.9a thread about another rom that was working for another member with the same problem. But I like Neomodes versions.
I would try the firmware i posted m8, at least to see if it works, untill neomode releases another one
Well, an update to where i am now.
I have two sticks, both so called MK809III, Both RK3188 no T at the end, but both have different wifi modules, which will only work as details below.
Module - AP6210 / T0D4005 / 1319 (Wifi works with any neomode version 1.9a or 2.0
Module - AP6210 / T0D5007 / 1320 (Wifi only works with link that "saschah" posted in the 1.9a forum) will not work with any of the neomode firmware
There is somthing very strange going on with drivers to the wifi, i would like to use neomodes 2.0 version, but will have to wait untill a new version and hope the wifi is sorted on these.
Hope that might help someone.
Re: MK809III AP6210 NEOTV CROM Version 2.0 1080p
Originally posted by neomode View PostThe Next release I will make will be for the RK3166 and the RK3188T as two separate Roms.
Neomode
Or else that i (and all the other guys with old wifi's) can use the rom in combination with the Sam kernel (old wifi is preloaded in this kernel), that works great on 2.0 with my 802iv and rtl8188 wifi
Sent from my GT-N7100 using TapatalkLast edited by wimmetje; 24 January 2014, 19:09.
Originally posted by mymkv View Postcan someone recommend 2-3 port hub adapter with RJ45 ethernet port which will work with MK802IV? Thank you.
and works perfect.
Neomode
There are currently 2135 users online. 0 members and 2135 guests.
