MK809III AP6210 NEOTV CROM Version 2.0 1080p
    Originally posted by neomode View Post
    No I didn't try it. Also I ran a Custom Firmware on my S3. Have you try the AllCast Software it is free in Playstore.
    Neomode
    If you have at least Android 4.2 in your S3 Miracast is supported and it should work. All Share Cast Software works only on Samsung SMART TV and All Share Cast Dongle because it uses a proprietary protocol. Miracast, indeed, is a standard WiFi Display. Could you check please?
      The best ROM for RK3188-T stick
      Hi Everybody!
      First of all , thank you Neomode for your endless and good work!
      I am noob, this is my first Mini-PC, so i have an Ippli Mars I2s (I've never seen I2s except mine) maybe because of 5Mpx camera. I tried many roms that i found, and I have to tell you, the best is this Neotv 2.0 , with kernel3 (included in rom package) its working like a charm native resolution 1920x1080 ~, 1080p videos perfect even trough wi-fi, AnTuTu aprox. 20200 , except Bluetooth, I realy need it. Is there any chance, for working bluetooth, are you working on this ROM till? or in the feauture?
      Thank you again for your hard work
      Best Regards
      R.
        Yes I always update my ROMs. For your Device did you have a link for the original firmware ?
        That Bluetooth not work might be a gpio problem that's all.
        Neomode
        Gesendet von meinem GT-I9305 mit Tapatalk
          Neomode
          Thanks for quick reply, i dont know if this is official, but this was on it before
          (password: geekbuying.com)
          R.
            HDMI Passthrough (DTS, DD5.1, AC3 etc) not working
            Originally posted by Phycopat View Post
            First great work!
            And now to the bad part:
            1. HDMI Passthrough dosent work here, or it does PCM2.0 is all what i can get, no DTS, DD5.1, AC3 5.1..
            The HDMI Passthrough worked nice on your 1.9a..
            2. the OC part is not working here.. 1.2Ghz max.. Have seen same problem on other ROMs also..
            3. BlueTooth, but you did say so. - will come in time i hope
            4. Some frame skip on netflix, but maybe thats because of the low CPU speed ? Did play a 720p from SD without problem..
            My device is MK802IV new chip like yours.. Date: 2013-12-02
            Everything else seems to be working..
            Am I doing something wrong or is there a problem with the HDMI Passtrough in this version? Every thing else works nice except for this. I tried HDMI Passtrough with 1.9a and it worked fine. Am I missing a setting somewhere?
            Best regards,
            Fredrik
            MK809III RK3188-T AP6210 running Neomode 3.1
              AW: MK809III AP6210 NEOTV CROM Version 2.0 1080p
              Might be a kernel problem. I am not able to test it.
              Have you take a look under settings sound?
              Neomode
                Sound - settings
                Neomode
                I have tried with all soundsettings that have "passthrough" in the name. I use SPMC and when I change the audio output in SPMC from Analog to HDMI I only get "White noice" as sound. As I said it workes fin in 1.9a.
                I will go back to 1.9a now but I would really like to run 2.0 with 1080p...
                PS.
                I have Another TOTAL noob question...Which USB-port is for Power? the one on the back or the one on the side?
                /Fredrik
                  @Fredrik
                  I have a stick Ippli Mars I2s rk3188-T with this rom and Beyond XBMC spdif passtrough is working, but only ac3 DTS not. On setting set the ultimate item i ROKCHIP-HDMI-PASSTROUGH and in xbmc audio output optical/coaxial or HDMI it should work on yours too
                  Tapatalk-kal küldve az én M6Pro-el
                    Originally posted by rruzsi View Post
                    @Fredrik
                    @rruzsi: I have tried some different settings and got it working with Beyond XBMC. Other players like SPMC, MXplayer, ESPlayer can not passthrough dd, dts etc. The next thing now is that the quality of 1080p video in Beyond XBMC is crappy but in MXplayer 1080p runs smooth. So I have to choose between multi channel audio or 1080p video. Im really open for sugestions.
                    /Fredrik
                      /Fredrik
                      Did you find audio output settings on Mxplayer, because I don't!?
                        Its strange that SPMC cant pass through DD, DTS etc because its so extremly similar to Beyond XBMC.
                          Neomode
                          Hi Neomode!I know you are very busy, just one question, a tried this rom with system.img from 2.1 and bluetooth works, can i resolve this issue or i have to wait for you?
                          Bye!
                            Ok then you only need to change the kernel.img with your kernel img than it should work.
                            Neomode
                              I changed only the system.img because other kernels not work for me, only (ncr19_mk809_kernels) the others allways screen flickering. with stable system3.img (3,12-1412) and system.img from NEO 2.0 no bluetooth, but with system.img from NEO 2.1 bluetooth work, with same kernel.
                                Hi @neomode
                                I´ve got a MK809III with the RTL8723BS and I have a lot of issues with stability.
                                I wanted to ask if it would be possible to add the driver for the RTL8723BS to this ROM?
                                Additionally I hope to get the system stable, because it´s rebooting often, even with a 3 Amp connector.
                                Added some pics to show you the version.
ID:	437377Click image for larger version
ID:	437378Click image for larger version
ID:	437379Click image for larger version
