MK809III AP6210 NEOTV CROM Version 2.0 1080p
Originally posted by imaddiced2u View PostGood, thsnks again.
I just tested a suspicion i had that it wasn't hard locked.
Not that it hasn't been done before its just cheaper to do it with software.
Since cheap seems to be the motivating factor with these devices i decided to test.
Now that neomode knows where to look things should be different for future kernels.Mk802IV Neomode 1.9a original rom 720p
@neomode I also have a 3188-t and also a bitchy wifi module from the looks of it (6210) I use this stockrom with a vsync fixed kernel (kernel from the stockrom) as its the only kernel where my wifi actually works. (even if badly) http://www.freaktab.com/showthread.p...-dan-Vsync-Fix No oc settings or anything, but the cpu runs at 1.6ghz which I guess is stock for non -T cpus.
Hi Neo,
These kernels http://www.4shared.com/zip/VPRYcf3pb...0pkernels.html works great with your 2.0 . My mk802iv is oc to 1,8 ghz and it works with the new wifi driver. Only problem is that the video stuttering is back with these kernels, but else i works really good. Maybe you can fix the video stuttering? Then we got 1,8 ghz on your 2.0
Basmand
Originally posted by basmand View PostWhat about Bluetooth, still no go!! If wifi works, I cant understand why Bluetooth doesn't works, it is the same module and ordinary driver, well that's probably why I am not a developer!!!
Basmand
Looks like neomode already got a idea whats going on.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostIf the connection to the module is broken then it wont matter if its the correct or not.
Yes I know, its just like Christmas, while we are waiting for the new MK802IV rom, so we are just like children's!!!! or I am
Basmand
Here is the stock rom for my mk 809 III R-Box. It allows cpu to run from 300MHz (or maybe 400?) to 1,4GHz. Link: https://mega.co.nz/#!PFtlCCYa!Fkwhvj...d7fsDEhnEy-jqQ
Hope it will be usefull for Neomode.MK809 III - Geekbuying december 2013
Originally posted by arsuna View Post@neomode I also have a 3188-t and also a bitchy wifi module from the looks of it (6210) I use this stockrom with a vsync fixed kernel (kernel from the stockrom) as its the only kernel where my wifi actually works. (even if badly) http://www.freaktab.com/showthread.p...-dan-Vsync-Fix No oc settings or anything, but the cpu runs at 1.6ghz which I guess is stock for non -T cpus.
If this is right please post a CPU-Z SCREENSHOT!
@Neomode @Tvdrop
If the kernel in the link can push our to 1.6ghz (maybe the maximum speed?) please test it and try to update yuor neotv 2.0 to make our rk3188-t running at this frequencies!
If I'm flashing only a new kernel do I need to erase IDB or not. When installing a ROM, do I have to reinstall apps, etc, or can I somehow backup/restore the state of the apps and settings of my MK809III?HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by Gianca90 View PostHi arsuna... so are you saying that your RK3188-T IS RUNNING AT 1,6GHZ???
@Neomode @Tvdrop
CPU-z tells me the apk has a wrong signature when I try to install it for some reason.
Originally posted by arsuna View PostYes it is, but I cant post a cpu-z screenshot right now. I can post a Antutu screenshot, though.
After that try to use other app similar to cpuz; for exemple try to download "CPU Spy" or "CPU / RAM / DEVICE Identifier" or similar app. If you search "CPU" on the play store there are a tons of Cpu-z like program. After that posta a screenshot
Waiting news from you; cheers
There are currently 2040 users online. 2 members and 2038 guests.
