MK809III AP6210 NEOTV CROM Version 2.0 1080p
Re: MK809III AP6210 NEOTV CROM Version 2.0 1080p
Originally posted by TVDroid View PostHow i can turn my Device real Off with the new Menü ?
The Light goes not off and i cant wake up the Device again when i ShutDown with the Menü.
Any chance to get the normal Shotdown Menu back again ?
Thanks!!
AW: MK809III AP6210 NEOTV CROM Version 2.0 1080p
Originally posted by _aaabbb View PostWhere i can find: Extra Software Package
(File Manager, Reboot App,Black Screen,FreakBrowser,No Frills CPU Control,Terminal Emulator)?
Good work. Tonight i will test it. For now, everything ok!
Thank you
Neomode
Originally posted by mymkv View Postwhy you are shutting down your device? it consumes very little power. keep it on
You have the US V8 BIG BLOCK thinking, right ? BIGGER; BETTER; USA
Just fun Dude
Back to Topic...
NeoMode what you say ?? I got never a answer from you, why ??... TVDroid
> > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
UTF8 Networkdrives
Hi All, I`ve currently running xubuntu on my mk809iii because with android i was not able to open folders containing ö, ä etc. or play songs from my networkdrive. So my question now Is it possible with this c-rom and/or can an app help? Further it would be helpful if someone can post a link how to implement an external german keyboard (if it is possible?). Thank you for your great work, free sharing and endevored updates. Rgds.
Thanks!!
Impatient to test this new rom. I hope this evening !MK809 III - Geekbuying december 2013
With the old Shutdown Method, i can easy turn off my Device.
1. Press ShutDown Icon and than ok.
2. Change the Input on TV, from HDMI to TV
Than the Stick goes off and the Light is out.
But With this Menü, the Stick is always on.
And next Problem, every Kernel from FlashIT App is 1.20GHz - 1.42GHz on my Device. I flash all, but all max 1.42GHz. Or i need to download the Kernel first ?!? The App want Root Rights and make a Rebot...
EDIT: The same with the Reboot App from the Pack.... TVDroid
@TVDRoid
Hallo,
Ich Antworte dir auf Deutsch, denke das wird einfacher sein.
Also Kernel must du keine runterladen, diese befinden sich im Rom.
Mit Flash It! werden diese Installiert. Mein Stick läuft mit 1.6 Ghz Standart Kernel.
Ich teste es mal weiter mit den Andreren Kernels denke aber das es funktionieren sollte.
Was möglich ist, das der Stick es nicht will. Mal sehen. Probiere es jetzt aus.
O.k meine max. CPU liegt bei 1.6 Ghz. :-( Werde mal suchen was da nicht passt.
Neomode
There are currently 1472 users online. 0 members and 1472 guests.
