Pipo M9 Max RileyROM 2.6 KitKat
    What about rebranded Pipo's (Sumvision)
      What's the exact sumvision model of Max M9?
      Proud M7Pro owner and Freaktab fan
        This one. Been using riley rom pipo prior firmwares, no problem
        Ebuyer stocks 10 Inch Tablets and cheap iPads including iPad, tablet 10 inch Samsung, HP and more. Finance available and free delivery
          This is what Anna Ye said on pipo facebook:
          M9 old pcb Motherboard : 2 NAND, 8 storages each, total 16gb M9 new Motherboard: 16gb nand, 1 pc of nand chip And this 4.4 firmware can be used for all new PCB Motherboard but not all old PCB Motherboard.
          Getting confused since it sounds contradictory to her email to riley & what dnkn discovered.
            Re: Pipo M9 Max RileyROM 2.6 KitKat
            Originally posted by remi252 View Post
            compatible or not ???
            Looks like it is compatible, see in upper left corner 2 chips with white marker signed.
            I've wrote to Pipo explaining that the problem exists, they believe that their kk ROM is fully compatible, but it's not. There are few ppl on our Russian forum who also got bricked.
            As for identifying the 2chips version, seems like flashtool's log may show it.
            my version shows
            4 times 4096 Intel
            So if yours show 2 times 8192 that is compatible one I guess. Don't have one, so can't confirm.
            I tried to adapt this ROM for the old loader but it does not boot. Serial console shows kernel crashes. Nand module crashes, no sources available even in leaked SDK, so there's nothing I can do. I can make a "Frankenstein" version with some part from this ROM and other from another pipo tablets, but...I don't think I should. It definitely will be buggy.
            I think it may be helpful if some of you who bricked will write to pipo's support that you've bricked your device with 06042014 firmware that may open their eyes on this problem. Don't mention Riley ROM . rr2.6 based on 06042014 fw,and it's no Riley's fault that it bricks some devices.
            Отправлено с моего ZP900 через Tapatalk
            https://www.paypal.com/en_US/i/btn/x-click-but11.gif
              Is RileyRom 2.6 based on the kitkat beta update.img?i was just wondering because the update.img works great on my tablet but this refuses to,after installing kitkat via the update.img im able to flash and run the system.img from RileyRom2.6 but flashing the kernel bricks it.
                Not booting does not mean bricked.
                Bricked device cannot be reflashed . without shortening the pins inside the case...
                Отправлено с моего ZTE V975 через Tapatalk
                  Ok!!
                  Why not try to download a "System Info App" and run it on your tab while you have "jelly bean" on it, the system app will tell you if you have one NAN or two, if you have two nand, will it not say 150000 or some number. That "High" number means that you have the wrong tablet for this ROM, if it shows "4000 or what ever the low number is, then this rom will load, I tryed it on my "PiPo and my Galaxy Tab 3 Both are "16GB", and the pipo showed the low number (4000?) and the Galaxy showed the High number and I know that the Galaxy has One nand, while the Pipo has Two, and right now I have this Rom loaded onto the pipo max9 16gb wifi only.
                  Check it out and see for yourself, the sys info app shows you everything inside your tab if you have root...
                    Sorry i meant not booting,it can still be detected and flashed via pc but nothing else.So is it safe to assume RileyRom2.6 is not based on the KitKat beta FW posted in RileyRom2.5 #127?My device is 16gb dual NAND and only runs the beta Fw fine if that helps anyone.
                      M9 Max old PCB
                      Firmware (4.2.2) for old PCB
                      M9_pcb_1.1_20130527_Android4.2_No3G_chinese_update #95.rar
                      百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
                      Maybe it could help for unbrick, I don't know...
                        Hi ghforlife!
                        Which "System info app" do you exactly mean? Could you please send us a link about play location?
                        Thanks!
                        Originally posted by ghforlife View Post
                        Ok!!
                          Originally posted by jettison View Post
                          Hi ghforlife!
                          Thanks!
                          I jjust use "asystem Info App" from "google play" you can use which ever one you like, they all will give you the info of your system., aSystem put's it in catagores and I like that.
                            Ok!!
                            So you got this working on a 16gb dual NAND?Interesting,because it certainly refuses to work on my 16gb dual NAND 3G version.
                              Does anybody have a link to the official firmware this is based on?I want to try flashing the original to see if it works.
                                It's on the 2.5 thread.
                                Sent from my U8 using Tapatalk
                                Randy
