So should mine be OK to proceed, then?
Pipo M9 Max RileyROM 2.6 KitKat
Originally posted by williamh120 View PostWell, further to my post above, I have just flashed the latest RileyRom 2.6.2 to the tablet I mentioned above (with the Toshiba chips in) and at the moment it seems to be working a treat!
Thanks, Riley!
Hi all I updated to the 2.6 ROM with no problems it appears to be very fluid and fast even though it gets a lower score than the 2.5 rom on An tutu? I would say its defiantly an improved ROM. Thanks for the ROM rrileypm I have only found one problem it appears that google location will not work. I may need to reflashas I've checked all the usual culprits.
Ken.
Not 100%Randy
Audio & out of sync while streaming Live TV
Just installed new RileyRom 2.6.2. Works great, especially when ART is enabled. Just one little inconvenience really. I watch live TV on my tablet frequently using Filmon app, and i noticed that audio and video are out of sync (about 1 second apart). It may have something to do with flash. Any clues?
WIFI problem with the 4.4.2 (Official & RRom 2.6.x)
Hello all,
I have a problem with WIFI on the 4.4.2 Beta Rom (tested on Pipo official rom and RRom 2.6.x).
I would like to find a solution to that but I don't know if it's a problem from my ISP or from the 4.4.2 FW.
My 4.4.2 Rom (Official or RRom) WIFI setup is :
-> Wireless and network -> advanced :
Keep WIFI on during sleep : Never
Avoid poor connections (Check or uncheck -> same probem!)
WI-FI optimization (Check or uncheck -> same probem!)
The problem is that my M9 Max cannot connect to wifi when the tablet is back from deep sleep ('Searching for wifi networks...' error!)
Dmesg -> 'IP si not available' error ???
Everything is ok when I set 'Keep WIFI 'ON during sleep' to 'always'
Am I the only person with this problem?
Re: Pipo M9 Max RileyROM 2.6 KitKat
Originally posted by neiliewheeliebin View PostThere does seem to be a bug,my WiFi wouldn't reconnect after deep sleep either,keeps saying disabled.I had to set it to always on during sleep and restart the tablet or the connection would keep disabling itself randomly as well.
Sent from my M9 using Tapatalk
Originally posted by boreus View PostJust installed new RileyRom 2.6.2. Works great, especially when ART is enabled. Just one little inconvenience really. I watch live TV on my tablet frequently using Filmon app, and i noticed that audio and video are out of sync (about 1 second apart). It may have something to do with flash. Any clues?
Originally posted by neiliewheeliebin View PostThis is an annoying bug,its out of sync when watching streaming TV directly from the FilmOn website also,and the mobile YouTube website crashes the browser and doesn't play most of the time as well.It doesn't work from any browser.
There are currently 4873 users online. 0 members and 4873 guests.
