Pipo M9 Max RileyROM 2.6 KitKat
Originally posted by saints5354 View PostHi rrileypm, this is the best rom for M9 Max so far, no lagging issue when wake up.
I have serious lagging on my table to the point of not wanting to use it - boot up time = 3 minutes and then constant lagging when performing any small action like switching browser tab
Android 4.2.2 Rooted and bloatware freed.
Originally posted by TechnicGeek View PostHello. Is this the only lagging issue you have had?
With 4.2.2 i had the problem that you describe which i fixed (sort of) with Mounts2SD mod but with this rom things are way better.
Originally posted by kandilak View PostIf your tablet's nand chip is compatible with this rom then you have to try it cause there is no lagging problem.
I just updated KitKat from this thread but I can't get tablet to work. I get Android animated logo loop.
Originally posted by TechnicGeek View PostI read that up to Android 4.3 previous versions had problem with TRIM lacking optimization and that since Android 4.3 it was supposed to be fixed. Maybe that's what we had?
edit: The rom that you have flash is less lag free than this because it uses old loader
Try Viper4Android.Randy
Use the FX version. You will have three driver versions to pick from. Only one will work, but I don't remember which one. It doesn't hurt anything to try until you find the correct one.Randy
Thanks for jogging my memory!
Sent from my P9Randy
Originally posted by Nordo View PostCan anyone tell me (with a photo?) where the wires are from the screen to the circuit board?
The touch screen on my wife's M9 Max has become unsensitive in some areas, and I've read that it may be a bad solder joint.
Thanks ghforlife.
Really good clear video.
Is he actually trying to achieve/repair something, or is he just showing how to pull the Pipo apart and put it back together?
Regardless, I'll go ahead and strip it down and re-build it.
Initially my problem was a jumping screen. After opening the back and having a fiddle, I put the back on and the problem had moved from a jumping screen to a partially non-responsive screen.
I'll let you know what happens.
There are currently 3332 users online. 0 members and 3332 guests.
