Pipo M9 Max RileyROM 2.6 KitKat
You need to ask that question on the thread for the ROM you installed. This one is for the 2 NAND chip models. I didn't do the 1 chip ROM.Randy
Re: Pipo M9 Max RileyROM 2.6 KitKat
Originally posted by tytux View Posthello im a noob, i have install your room with the modification for 1 nand chip, and it works, but the root is not working, it ask me the binarys.
How can i root this 4.4??
I have a 3G model, and location mode and 3G didnt work. For that I have mix that Rom with RileyRom 2.6.2. I have flash loader+boot.img+recovery.img from dnkn ROM and other files from riley's.
Location works great, 3g works great, but something strange happened, I have SuperSu but I dont have Root access. I have tried with Kingo app and with Tp-sarky-Vondroid and I havent success ....any ideas?
EDIT: Trying to reflash the mixed ROM I realize that in ERASE IDB 4096 only count to 4090 and write "current (6)"....I am confused.
I should try to mix the other files of the Roms?
Thank you
EDIT AGAIN: Reflashing again I have flash loader+boot.img+recovery.img +SYSTEM from dnkn ROM and other files from riley's, and location works, SuperSU works but 3G signal dont...I surrender in this step😧
Originally posted by ghforlife View PostI've tryed a "USB" key broad and a "Bluetooth" and both work, also when you first turn it on, (From the time you push the button untill you get to swipe screen it takes "35 sec." in five different times. Home button under "device's" has two different "launchers" (launcher3 and google now launcher) both work, but on the launcher3 you are unable to remove the google search button, or at least i can not remove it...
That pblem with search box/velvet also makes me crazy.
On mfathers m9pro i couldisab google search on another 4.4 rom i am using i cannot disable, it is greyed out....
So on this rom youlso cannot disable?
I believe we are working with wifi only firmware on this ROM...sorry.Randy
That answer will have to come from the users actually running the ROM's. I don't have an M9 to test.Randy
went back to stock after bricking it...
went back to stock but I forgot to erase nand first...
well the tablet wouldn't power on...
I fixed it without having to do the trick with shortcircuiting...
while having the tablet connected to my laptop i pushed the on button continuously, and suddenly I saw that the finless tool could see the tablet ... I left the button and the tool could see nothing...
so with the power button pressed all the time, I erased nand and then with the rk batch tool (while having the on button again pressed down all the time) I flashed the stock rom...
You should be good. You have two NAND chips, which makes it compatible with this ROM.Randy
Originally posted by Sprkuy View PostUntil now is impossible to know 100% if the ROM will works without open the device?
But you can also use Android tool inside of rkdevelopment to read system info.....
When it shows cs0 and cs1 you have 2 nands....
BUT opening is fast and easy amd SAVE to know if 2 or 1
There are currently 2466 users online. 0 members and 2466 guests.
