Sent from my GT-I9505 using Tapatalk
Pipo M9 Max RileyROM 2.6 KitKat
Originally posted by neiliewheeliebin View PostIs anybody else tried using an external SD card larger than 16gb on KitKat?I tried a 32gb card and it totally killed the external SD card reader.Did a full wipe and reinstalled jellybean but its still dead.On jellybean it just used to unmount and corrupt the SD with an incompatible card but with KitKat it appears it may have actually caused permanent hardware failure to the reader,it might have been a coincidence but i thought i should warn people anyways.
I'd only just taken delivery of a 32GB microSDHC card but had not yet tested it. I was worried I was not going to be able to use it for exactly the purpose for which I'd intended it.
But, it seems to work fine with my M9 Max!
(However I realise this means you might have faulty hardware or a bad card)
Re: Pipo M9 Max RileyROM 2.6 KitKat
Mines always had a 16GB reader,and I've got another Chinese phablet advertised as "microSD 16gb max supported"with the exact same symptoms,can't handle any card larger than 16gb,randomly gives the "error storage removed unexpectedly" message. and corrupts the card.For whatever reason my M9 came with the same limitation.I must have got a bad chip in mine or something.I want to send it in for repair but if they replace the mainboard with a newer 16gb board I'll get stuck with 1 NAND and no KitKat,there's no way I'm ever going back to jellybean on the M9 again.I'll email them and see what quotes/options they give me.
Trans Flash TF Micro SD Card Socket Adapter pop-up micro for PIPO M9 Max replacement
If this can help someone..
I had the same problem when I openened up my M9 Max (forgot to remove the sd card!)
I ordered from this guy and the TFCard adapter is 100% the same than the one in the PIPO M9 MAX
Originally posted by neiliewheeliebin View PostI did the same thing to mine,tore one of the SD card tracks off the board with it,had to bridge it to the other side of the PCB with a fine wire,not fun.
Originally posted by fatbottom View PostDecided to bite the bullet flash the Sumvision Voyager 2 10.1" quad core 32GB. Didn't brick it.
I didn't open it up to check haha
one thing I have 10GB NAND flash but where is the remaining? It's the 32GB model.. 3GB internal storage
Originally posted by fatbottom View Posttalkinga about internal. says 10GB NAND, 3GB user
but that's 13GB. Where's the rest? I know some of it is used as system- but not that much! I know sometimes with flashing you need to format storage, but it appears in storage, I can't see anything
32GB external SD...
I belive he format the nand per idb and the new Firmware format it new to 16GB. So if you want to have 32GB again you have to format again with a proper Firmware.
Chris
2 nand chips?
Originally posted by Majdanac View PostHi. I have a pipo m9 (not pro) and i opened the back cover and did see two sandisk nand chip called sdtnqgama-008g. I bought tablet in december 2013. Kernel version 3 and is 16 gb version. Can i flash tablet with this rom?
Thanks in advance!
There are currently 2140 users online. 0 members and 2140 guests.
