Pipo M9 Max RileyROM 2.6 KitKat
Originally posted by ghforlife View PostThe KitKat rom that I have is for the 16gb, that is the type of tab that I have, this ROM came from cshock 2010 in thread; rileyrom 2.5 post##127 or 128..…
Where he got it from I do not know, I just downloaded it and it works really good, I just used one of Riley's tools and flashed it
Can I double-check with you what you've said:
1. You have 2 nand chip version.
2. Downloaded original firmware from 2.5 thread provided by Anna Ye, not rr 2.6
3. You used rkbatchtool 1.7 to flash update.img
Is that correct?
Thanks!
I extracted the original firmware images from the update.img and tried flashing them with the ROM flash tool included in RileyRom2.6 and that wouldn't work either.With the working official beta firmware already installed I can reflash the system.img and it keeps working but if I try reflashing even the stock kernel it won't boot and needs the entire update.img reflashed to get it working again,is there some trick to flashing kernels with the Gen 2 loader?
Is that correct?
Thanks!
Originally posted by neiliewheeliebin View PostSo you got this working on a 16gb dual NAND?Interesting,because it certainly refuses to work on my 16gb dual NAND 3G version.
Is that correct?
Thanks!
Yes, however I did not know at that time, this os would/could brick my tab. It was only after I had loaded it onto my tab that I found out that it could, I was very lucky...I should have read more, before trying it, but I was so greatfull to have a "Stock KitKat" for my tab.
Originally posted by ghforlife View PostYes I have, but this is the problem with this tablet, that I'm seeing, some things work and others do not. I downloaded the OS from the link on rileys 2.5 thread not knowing this could happen and it works real good. I have been trying to get the one from "OMA's at xda devs thread, to work on my tab and it would not work, then I came across this one and it does, it must have something to do with the motherbroad, old vs new I do not know, I only know that it work's on my tab and I am greatfull to that, good luck with yours....
Originally posted by fztt View PostJust curious... did anyone brick their tablet flashing the original beta firmware instead of rr2.6 ?
Originally posted by neiliewheeliebin View PostSo you have downloaded and flashed RileyRom2.6 from here?and it boots fine for you?with CWM recovery and all?
I said that, I have been trying, OMA's verson and could not get it to work, because of the rotation, all of OMA's roms does not work on my tablet even if change out the kernal (PiPo Max M9). Some other rom as well do not work on this tablet, but if you read in xda you see that some people are having the same problems with the pipo m9.
My tablet works realy good with this rom, why Rileys rom, does not work on some and do on others, I do not know, it is the same rom, just "Rooted" and blot-ware taken out. He does "GREAT" roms, at the time this KK came out, he did not have 2.6 out.
If you would like here is a "link" to the same rom, read it and see what you thank; ,(http://www.arctablet.com/blog/forum/...ware-20140604/) this person does good work also.. but if you keep on reading you will see that this tab works with some not with others..
Sometimes you have to use a little process of elimination to figure out why things don't work.
If you say the stock version of this firmware works, but my ROM doesn't, there must be something I've done in my process that prevents the ROM from booting on some tablets.
In the past, I've encountered problems booting from something as simple as a bad graphic file in the boot.img, or kernel.img...or a boot animation that doesn't seem to work. I've also had problems with too much debloated...or a module that I've loaded that hangs the boot process.
Because of this, I've done a redo of this ROM (2.6.1) with:
Different boot animation
No boot.img graphic
No kernel.img graphic
Less debloat
No insmod for the ko modules
Let's see if it will boot. Can someone test this for me and report?
DownloadRandy
There are currently 1080 users online. 1 members and 1079 guests.
