I posted v1.5 RileyROM last night.
Pipo RK3288 Tablets: Discussion
That's just saying that there's another firmware update.
I posted v1.5 RileyROM last night.Randy
Ok Randy and what does it more than the rom pipo p1 came with.
I only want to give it a try if someone can explane the benefit of updating.
Till now no one could explane EXACTLY what it brings to change from the original rom to one of the updates available.
I'am not a real tweaker so lot of people as me are wondering why should a take the risk to flash another rom.
For me the configuration my pipo p1 came with. Working fine so what I'am overlooking ????
Cheers
I don't get change logs with these firmware versions...but the original file name mentions WPS...whatever that means. I haven't had much time to test any other changes.
Also, something about "Direct Power Plug Charger"....I'm not sure about that, either.Randy
Have you seen the ROM thread? It explains all of the features.
Sent from my P1 using TapatalkRandy
Originally posted by androider View PostNO Randy ,
And a lot with me.
So to get if simple and not explane what the updates do.
WHAT IS WRONG WITH THE ORININAL CONFIGURATION?????
krgrdsif you appreciate my efforts this is the link for any donation:
Maybe I'am a dummy in this. ( ok I'am)
Still do not understand why I should update and what exactly is the actual improvement,
If I read all the updates there is always someting buggy so there is an need for another upate to rectify the previous one .
Again what do you guys can do more with your tablet as I with my original configuration??????.
Give me one example what you can do with your updated pipo p1 what I can not?
My tablet does not hang does not reboot and all is working smootly.
No...you are no dummy. You have choices...and by what you are saying...you like to make educated choices.
Primarily, custom ROMs provide root. Beyond that? Depending on the developer there may be more added.
I haven't written this, but with these early rk3288 ROMs, I'm taking a conservative approach to making too many changes until we get more of a baseline of how the firmware performs.
Aside of rooting, I make little tweaks to allow a greater number of apps showing as compatible on Google Play Store.
If you are into running init.d scripts...that feature is added...and the symbolic links to busybox commands are added.
Also, if there are known issues, I've come up with workarounds or tweaks to improve certain features. But so far on the P1 I haven't needed it.
I too have had positive results with my P1...no lockups, no reboots...no lag....no problems whatsoever. This is the smoothest tablet I've owned...and I have a whole drawer full of tablets to compare.
If you are happy with the stock firmware...by all means...rock on with it. But if you need to run an app that requires root...like Titanium Backup...I would encourage you to flash a rooted custom ROM...whether it is mine or somebody else's.
The kicker is doing it the first time. Getting the USB drivers installed properly can be a pain in the butt.
My tablet does not hang does not reboot and all is working smootly.if you appreciate my efforts this is the link for any donation:
Thanks Randy,
Ok this is clear to me some apps need a rooted tablet ok I can understand it.
And to get more apps showing as compatibel is for shure a good thing.
Please do not understand me wrong all over the place one can read about the good work you have done in the past and on the local forums overhere nothing than positive postings,I just wanted to know if for Pipo P1 it is word to update or not.
I will follow the topic from here and if it is realy a big change I will change.
Just as Giouncino advised too.
By the way this new tablets are in no way to compare with the old ones.
Maybe Pipo did not release this time with the problems of the past.
Maybe my seller already made some adjustments as there are zero Chinese things on my tablet and he already did change the settings for my country.
Cheers and a good weekend.
Cheers and a good weekend.if you appreciate my efforts this is the link for any donation:
There are currently 3140 users online. 1 members and 3139 guests.
