TX5 Pro Official Stock Firmwares, updates and discussion
Originally posted by Cavaliere View Postokk with the sd card how do you upgrade there is' a guide ?
While this version ATTACHED and ' Official or Not?
1) extract the rar file in the microSD card;
2) power off the TX5pro;
3) insert the microSD in the TX5pro;
4) under the TX5pro there is a little hole, insert something inside and keep pressed the button;
5) power on the TX5pro while keep pressing the hidden button, the recovery screen should appear;
6) if update doesn't start automatically, choose "install a zip" and select the firmware zip in the microSD
7) when update finish, reboot.
All your stuff inside the box will be erased (customizations, downloaded files, pictures, videos, etc.).
The firmware in that thread that you linked looks like the previous one, you can see the version/date:
the img file in the link is 20160805
the rar file in my link is 20160813
All links come from here:
http://blog.geekbuying.com/index.php...ware-20160809/
Originally posted by SandroID View PostHello all,
I have a probem
Deep color option do not turn off as I understand
My projector shows very dark place on screen. And it do not have fullRGP settings as I understand.
It seems that switching deep color do not work on 13.08.16 firmware
I think I can't be the one with this problem...Last edited by SandroID; 09-24-2016, 08:41.
Originally posted by PM+Mickey View PostHere is a new firmware for Tanix TX5 pro. This time for update from PC.
!!! I have read that with this firmware LibreELEC can not be used from uSD card and I did not test this build because I use LibreELEC !!!
http://www.mediafire.com/download/69...o-20160909.img
I'll update the first post with the link.
Do you have a link to the source confirming that LibreELEC cannot be used in tandem with this firmware?
Here is the link: http://forum.libreelec.tv/showthread...13393#pid13393Last edited by crypted; 09-26-2016, 06:45.
Originally posted by crypted View PostHere is the link: http://forum.libreelec.tv/showthread...13393#pid13393
Gesendet von iPhone mit Tapatalk
Last night I tested 2016.09.09 firmware.
New boot animations.
Top bar
new apk for updating KODI plugins
new apk for dump log on removable medium (need to create some file on medium for activating)
new apk for help info
still autoframe rate problem
confirming that with this build LibreELEC can not be used from sdcard
( twrp backup did not resolve LibreElec problem) also tried to manually use boot.PARTITION, bootloader.PARTITION in level1 dir of unpacked firmware from 20160805 and pack and flash but LibreELEC still can't be used.)
Reverted back to 20160805 and update from uSD card to 20160813
Top bar
I tested briefly the new firmware. My findings until now:
- the new boot animation is the original Android 6 one (like the Nexus phones);
- the enter button bug is still present;
- the CEC function now works properly on my TV (previous firmwares don't);
- in the new Kodi plugins update app you can choose the plugins pack for your country/language. When you update with this app, all existing Kodi plugins, themes and preferences will be deleted;
- as you can read from the new manual app, the pre-installed Kodi uses an apk signature different from the one in the Play store (because it's a customized version of Kodi), so it won't be updated automatically (only with a firmware update or uninstalling the existing Kodi and install from Play store);
- the integrated firmware update tool doesn't work (it never worked in previous firmwares too);
- the security patch level is still August 2016.
There are currently 3020 users online. 5 members and 3015 guests.
