Good morning, I have a problem with kodi on my TX5 pro, goes into a sudden crash, how can I fix it? Thanks
TX5 Pro Official Stock Firmwares, updates and discussion
Originally posted by Rigattoni View PostHi guys,
any idea to get rid of the settings menue?
I would like to get back the "normal settings" instead of the big icon settings menue.
Any ideas around here?
It does to some extent make this messy though and I would like to see all options available under the default Google settings as well as in these big icons that may have some of them.
Hi, I bought Tanix Tx5 Pro and I realized the problem with the key 'ENTER'. I solved installing "External Keyboard Helper Pro". It has many functions like Remap any key (I set 'ESC' as 'Home', 'TAB' as 'Swicth App' and 'Backspace' as 'Back' for example and 'Enter' as 'Enter' to fix the problem), to change a keyboard layout (mine is pt-br) and it hide the soft keyboard too.
Somebody know how to make "Netflix for Android TV" (com.netflix.ninja) work on the TX5? I am using 20160823 rom version and it always force close.
Originally posted by victorvc View PostHi, I bought Tanix Tx5 Pro and I realized the problem with the key 'ENTER'. I solved installing "External Keyboard Helper Pro". It has many functions like Remap any key (I set 'ESC' as 'Home', 'TAB' as 'Swicth App' and 'Backspace' as 'Back' for example and 'Enter' as 'Enter' to fix the problem), to change a keyboard layout (mine is pt-br) and it hide the soft keyboard too.
Somebody know how to make "Netflix for Android TV" (com.netflix.ninja) work on the TX5? I am using 20160823 rom version and it always force close.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Which version of firmware is on your box? 20160909 firmware?
#1 Gearbest TV Box & Mini PC Page
#2 Flash Deals Flash Deals
#3Coupons Coupons, Coupons and More Coupons
anybody here with tx5 pro 20160909 firmware has been able to run latest clould tv?https://www.sendspace.com/file/6djo11
i still can't run this even after upgrade to 20160909.Last edited by vostro; 10-07-2016, 17:18.
20160909 firmware have a new issue:
- "Ookla Speedtest" App from PlayMarket - can not click "Begin Test" by mouse or by remote (of 10 attempts, 1 may succeed).
- "SuperSU" App from PlayMarket - can not click to "Expert Mode" at first start of App by mouse or by remote.
20160909 firmware still have an old issue:
- if we have bottom status bar activated by Settings > Screen > "Navigation Bar Toggle" > On :
when we hide status bar by mouse click to icon "hide" we can not bring it back by mouse, need to again select: Settings > Screen > "Navigation Bar Toggle" > On
and sometimes toggle "On" not work immediately - need to reboot device.
There are currently 3764 users online. 5 members and 3759 guests.
