Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&developers
回复: Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&developers
Originally posted by Haba View PostDo you expect RK to release the complete SDK in the future?
来自我的 GT-I9300 上的 TapatalkEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View PostI can't edit this post now,why?Help,Bob...
OK,I have chosen 18 people for the R89 testing,they are :
no_spam_for_me ,bloodgnome,LawlessPPC,4WheelSpyder,ssspacman ,ademturk ,Arbelzapf ,talas ,NikAmi ,goldenrod ,TMx ,sync ,sweup,Smokez,ENDRJUPL,clarkss12,Catadarius,tltest er..
and endera.................vs..
Thank them!
And we still want two more,totally 20.Others are for Developers.
The current state:
1.R89 can be powered on,but RK still don't release their complete SDK.We are doing some debugging and testing now.
and endera
Ok just my thoughts.
The bigger the heatsink the better (it would be nice to cover as much of the ram chips as possible to help cool them down as well) and the more conductive the metal the better so a copper heatsink is a lot better than an aluminium one. The greater the surface area of the heatsink the better also so the higher the villi or cooling fins the greater the surface area equalling even better cooling. Then as others have stated please use thermal compound (artic silver) as its far more conductive than any tape type solution but only as long as the heatsink has retention clips or a fixing bracket which it does at the moment. Also make some small vents on the base of the unit along with vents on the top of the unit this will cause cool air to be drawn in at the base as the heat rises and escapes out of the top by convection current. Wifi chip i would choose one that does 2.4 &5 Ghz its worth the additional cost. An antenna would be a good idea for the wifi also. Best way to test any networking speeds is to use iPerf available on nearly every platform. Do we know the spec of the NAND? How finalized is the pcb design?
Yep,you know,a product might achieve balance between cost and performance.
I know use the bigger heatsink ,with copper,and higher fins,thermal compound,vents,it will better for thermal solution.But it will increase cost,and maybe only decrease 2~3 degree?
The first thing I ask for my boss is use thermal compound,he agreed.
And for vents,because our case is already modified,it's not easy to change.If so many people care about this,my boss will pay attention to this. Pls show your attitude here to my boss.
For others,we must discuss.Copper is much more expensive than aluminium ,with less cooling effect.
Nand is Micron 8G now,but I am not sure which will be used in the final mass production .Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
pick me
I Would like to be considered for beta test. I have owned an mx1, cx919, t428, mk908, cs868, a1000g, cs918, q7 and a b4a. I also have a ifc6410 QUALCOMM development board on order. I have dolby/dts receiver, Bluetooth mouse and headset, f10 pro controller, fiber optic 50mbs internet and Panasonic 3d tv.
Well I guess it's not very wise to make decisions about cooling if you're not yet able to even run this thing at full clock speed.
Then only tests can show what is the most appropriate solution.
If there's a way to improve the cooler at a reasonable budget, I am certainly going to prefer that. We've all seen TV Boxes and sticks with thermal issues and it's not something that's easy to solve for the end user.
Originally posted by goldenrod View PostWow, an AC option! That is fantastic and will put those new AC routers to the test.
Definately my preference.
AP6210: WiFi 2.4G/BT4.0 WiFi 1T1R (65 Mbps)
AP6330: WiFi 2.4G,5G/BT4.0/FM,WiFi 1T1R (72.2Mbps)
AP6234: WiFi2.4G,5G/BT4.0,WiFi 1T1R (150Mbps)
AP6335: WiFi 11ac 2.4G,5G/BT4.0/FM,WiFi 1T1R (433Mbps)Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
There are currently 1585 users online. 1 members and 1584 guests.
