Sent from my HTC One_M8 using Tapatalk
Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&developers
Originally posted by Arbelzapf View PostI love seeing these progress updates. Keep them coming, oman
But now,I have one problem,how to test RGMII? we don't have any Giga routers,switches,Hubs.
What I am thinking one way now is using a Giga switches,and two R89 with the super-six Ethernet cable connected,but how it works?Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by raxy View PostI you don't mind,
I could add that holes in the pcb could help a some metallic spring hold the heat sink the right way and for a long time.
I could be wrong, though
Originally posted by csgabe View Post@oman
You can connect the R89 to a computer with gigabit lan directly through a RJ45 LAN cable.
But how it works?
ok,I will do some research.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by Arbelzapf View PostI think that is already the case. If you look carefully, you see the heatsink extending on both sides left and right, ending in a white knob. If you compare that to the picture of the whole PCB from earlier ( http://tinypic.com/view.php?pic=a43n80&s=8 ) , you'll notice a hole directly under the left-hand RAM chips. That's exactly where one of the knobs is. The other hole would be obscured by the green description area.
BTW,why your eyes so sharp like an eagleEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
oman-nicely handled
Great way in which you handled this (Choosing) your development crew. I am waiting for production, have recently found the enjoyment of programing and development with these mini-pc's. I hope that once R89 is released it will be as much fun as I am having with my RADXA. Waiting Patiently.
Later
AW: Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&developers
Originally posted by TMx View Postis AP6210 wifi chip the only option or is there another model with 6330 5ghz chip ?
There are currently 2359 users online. 0 members and 2359 guests.
