NEW-MK908II and similar devices CUSTOM KITKAT ROM by VECLINUX
List the devices your devices folks it seems the recovery with this rom is very device specific.
I can get it working fine on my MK802IV without issue but have had no time to test on others.
Unfortunately i have little time to mess with this now to a major health concern.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Geetek View PostI'll give twrp a try and report back...I have the T version of the mk908ii. Hope you feel better soon M33.
Sent from my GT-I9100 using Tapatalk
Still with treatment i should be more or less normal and its early in it for me.
The generic nature of this rom and the fact that its made up of both 720p elements and 1080p before veclinux ever modded it makes the recovery issue tricky.
Have to see if i can fix the normal recovery it be much easier to include in the rom.
I sporting a major mad on for obvious reasons so sleep not coming so all check on it tonight.Mk802IV Neomode 1.9a original rom 720p
@veclinux @magnus33
Thanks both for this! I've since upgraded to a NEO X8-H but was about to lend the MK908ii to a friend and saw this. It's working great so far, seems much more stable than Finless 1.5 which would crash a couple of times per day.
One minor issue. Is there any way to turn off the click sounds? Turning off keypress sounds in keyboards doesn't do anything.
Originally posted by Temporel View Postis this the latest/best ROM available for the MK908ii ?
Originally posted by Geetek View PostUnfortunately, had a lockup while rom was running, then got hit by bug where prompt comes up for password to decrypt storage at boot up. Trying out QS3.1 + d33 kernel for time being.
The memeory format is the same as all others so there should be no difference between roms.
Oh for recovery i would suggest matching twrp to the size of the kernel.
With this rom there seems to be a issue with this.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Scooberdanje View PostAnyone tried it on Tronsmart T428 and is it possible to flash it on a windows 8.1?
I uploaded the drive installer for 8.1 a minute ago so install that and things should flash normally.Mk802IV Neomode 1.9a original rom 720p
There are currently 2202 users online. 2 members and 2200 guests.
