NEW-MK908II and similar devices CUSTOM KITKAT ROM by VECLINUX
[QUOTE=anonymvs;231930]Where to find appropriate for my device? I've tried to flash the android tool by checking only the kernel path and marking the kernel.[/QUOTE
http://www.freaktab.com/showthread.p...All-(well-most!)
If you have the mk908ii then you need the ap6210 for TV sticks from above link, make sure you point flash tool to wherever you unzip the new kernel to(click box to right in kernel row) and only have kernel ticked
Originally posted by mavwolverine View Post@Magnus33 "Screenscale is fixed"
Just curious, how did you fix it? Trying to get my hands dirty and learn about roms.
Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostUsed this tool to open the iso and replace the broken displayd file.
http://vondroid.com/threads/rk3xxx-f.../#.VCZRzxarjEI
Will also try the vondroid tool.
Where do I get the fix for display file? From the official rom?
Thanks.
I was pretty much ready to throw out my MK908ii until I discovered this ROM!
Been testing it out all day and this is so much better than anything else I tested. Great work.
One question, is it possible to hide the on screen keyboard? I have a keyboard on my air mouse so would prefer if it didnt appear on screen.
Originally posted by Bazmamfoo View PostI was pretty much ready to throw out my MK908ii until I discovered this ROM!
Yeah just unselect everthing except the air mouse in input devices in settings.Mk802IV Neomode 1.9a original rom 720p
Re: NEW-MK908II and similar devices CUSTOM KITKAT ROM by VECLINUX
Originally posted by Magnus33 View PostYeah just unselect everthing except the air mouse in input devices in settings.
Sent from my SM-G900F using Tapatalk
Originally posted by Bazmamfoo View PostAir mouse doesn't appear in the options. Android Keyboard is ticked but greyed out so I can't deselect. I might look into see if there's something on the play store that could hide keyboard
What I use.... is the Null Keyboard app and works perfect
Google Play app: http://goo.gl/8ZM2Ji
Thanks for your hard work guys, this Rom is the best! I tried severeal on my fake cx-919 RK3188t and I find this one to be the most stable around with a perfectly working wifi.
The only problem I have is flickering when running a 1080p kernel but I heard it could be caused by a bad power adapter? It should be 2A output but I haven't tested to see how much it is capable of.
There are currently 1593 users online. 3 members and 1590 guests.
