I like to test this ROM, but I am without a PC, how flash this in this situation?. I have a linux running from sdcard booting from reovery.
NEW-MK908II and similar devices CUSTOM KITKAT ROM by VECLINUX
Re: NEW-MK908II and similar devices CUSTOM KITKAT ROM by VECLINUX
Originally posted by Modo View PostI'm out of ideas, this time it broke after I installed xbmc and started it with the addons I want. One final manual device reboot using the android menu to make sure everything was still dandy put the device again in the spinning circle state.
I will now just use the Wasser XBMC (?) installation that comes with the rom and hope it doesn't fail on me before reaching the point where I don't need to reboot the device ever again (or until there is some kind of a fix/workaround)
Originally posted by FadeFx View PostAh, ok... this makes a totally different picture
Cheers,
Vec
Originally posted by veclinux View PostMight be the same hardware issue could be failing nands as this sounds like the same sort of symptoms a pc has with a failing hard drive. But who knows the chinese interchange parts on these devices everytime they can save a few pennies so it just might be you guys got something different from the same batch run. My device has been running for months on this rom and hard as I have tried cannot duplicate the problem...................
Cheers,
Vec
I might try flash finless later and see if the problem persists.
I do love this Rom so hope I can resolve
Originally posted by Bazmamfoo View PostDon't think xbmc is to blame. Might be a Rom or kernel issue. Did you flash a custom kernel?
All streams on XBMC were very slow so I always kept an eye out for other roms. This one amazed me on that matter so I will just keep trying to use it. If I need to reflash the device every week I will probably switch back and await another update/rom to try out.
Cheers,
Vec
Because the Wasser XBMC installation wasn't running the add ons I liked I again installed the latest XBMC from their site and got everything configured. When rebooting the device I was expecting the problem but it just continued booting and we're using the device without problems.
Originally posted by Bazmamfoo View PostI've had the device for about a year now and this issue has only started since moving to this Rom. But as you say these are made quite cheaply and I move mine around a lot so very possible the power port has been damaged or something .
I have already tried going back to the finless rom and the issues were gone, but so were the 720p smooth streams so I switched back after 2 weeks
Cheers guys!
Originally posted by Bazmamfoo View PostWell I'm back in action lads!
Was an issue with the power cable or port. To fix, i used my Galaxy S5 phone charger in the OTG port and now it's running as well as ever. Very happy.
When I have that issue again I too will try a genuine power charger. I only have cheap Chinese usb-power adapters to spare right now but it's worth to take a shot with my apple adapter.
AW: NEW-MK908II and similar devices CUSTOM KITKAT ROM by VECLINUX
There are currently 1821 users online. 0 members and 1821 guests.
